It is currently Mon Oct 05, 2026 3:57 pm
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Tue May 24, 2011 8:22 am
Guys....
Just come across some 1ltr Diffs (Front 22spline & the Rear being 26spine)
Can u use the 4.1 R&P in the Diff's of a 1.3ltr NT ??
rob
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Tue May 24, 2011 8:28 am
Nope. They are too small. 1L have the same sized centre and R&P as LJ80.
1.3 NT and WT diffs are much bigger.
Post Posted: Tue May 24, 2011 8:35 am
Left field I know, but have a think about swapping the whole axles over. The housings are smaller for better ground clearance, and 1.3NT axles swap straight in as a CV upgrade over the 1.0 stuff.
Disadvantages are : rear brakes aren't self adjusting, you'll need 1.0 spring plates and U bolts as the axletubes are smaller diameter, and you'll need to make hybrid driveshafts, unis, or swap to 4WD light flanges on the transfer.
I liked my 1.0 axles under my trayback. Under some circumstances, my car was more capable on them with a rear locker only than with WT diffs and twin lockers and 5.12 gears.
Users browsing this forum: No registered users and 197 guests
