It is currently Thu Oct 01, 2026 6:31 pm
Post Posted: Sat Jun 04, 2011 6:29 am
gday fellow auszookers...
My quick question. Can connecting the wires back to front on the exciter of an altenator cause it to charge the battery at 17.4 volts???
Stocker
Vehicle: Daisy
Post Posted: Sat Jun 04, 2011 6:35 am
Have you got a multimeter?
Fire the thing up with the meter hooked to it and check?
internally in the alternator? or by back to front you mean swapping the sense wire and the indicator light into the back of the alternator?
Post Posted: Sat Jun 04, 2011 7:04 am
sense wire and indicator light :)
Stocker
Post Posted: Sat Jun 04, 2011 7:23 am
It can cause damage to the regulator..
Sounds like that may have happened.
Post Posted: Sat Jun 04, 2011 10:12 pm
Stocker
Post Posted: Sat Jun 04, 2011 10:15 pm
What alternator do you have
Post Posted: Sun Jun 05, 2011 2:41 am
falcon mitsu 100 amp jobby,
Stocker
Post Posted: Sun Jun 05, 2011 3:24 am
Stocker
Post Posted: Sun Jun 05, 2011 3:39 am
ok so i managed to get on the computer lastnight and have a good read over the tech advice on installing one of these alt's. I do have the sense wire and batt light wire the correct way around now the problem im faced with.
For some reason at idle i have almost no voltage coming from the alt it sits around 12.4 volts.
The second you give it a little throttle the charge jumps up to 18+ volts.
Ive tried it whilst under load (spotties and hibeams) on and it makes neglidgable difference i assume this could mean the regulator is fried??? Any help or confirmation would be appreciated
Stocker
Post Posted: Sun Jun 05, 2011 9:57 am
Anyone???
Stocker
Post Posted: Sun Jun 05, 2011 10:00 am
sounds like reg is fudged
Post Posted: Sun Jun 05, 2011 10:45 am
i had a similar problem but only went to 14.9 volts, all i did was hook sense wire directly to the battery i think. Wont go about 14.2 now :D
TWIN LOCK IT & JUST DRIVE!
Post Posted: Mon Jun 06, 2011 8:37 am
hmm... i tried hooking them up both ways... one way, 18 Plus volts, the other way, i get 15.2Volts...
Time to price a new Reg...
Stocker
Users browsing this forum: Google [Bot] and 106 guests
