It is currently Sun Oct 11, 2026 10:04 am
Post Posted: Tue Jun 28, 2011 5:02 am
hey guys i got underneath the sierra today to change the diffs, gearbox and transfer case oils
front and rear diff done without a hitch
fill plug on the gearbox is bloody hard to get access to with the 3/8" breaker bar i have i may need to get a smaller length ratchet so it clears the exhaust
but my question is the fill plug on the transfer has been butchered to shit - looks like the mechanic last time stuffed it putting it back in
question - how can i get it out without damaging the t/case and thread? small cold chisel tapping it around to undo it then install a new plug?
how would ya do it?
Post Posted: Tue Jun 28, 2011 5:30 am
yes u could do that
or u could weld a bolt on the end .. theres lots of ways i had great success on my diffs useing easy outs
also a tip when putting the new ones in dont over tighten them..
Post Posted: Tue Jun 28, 2011 5:31 am
10mm Square tool, I'm buying one from ebay.
helloo
Post Posted: Tue Jun 28, 2011 5:32 am
that all depends how butched the plug is ..
Post Posted: Tue Jun 28, 2011 5:35 am
they get butchered because people use 3/8 square stuff to try and undo/tighten the plugs
Vehicle: '96 LWB trayback
Post Posted: Tue Jun 28, 2011 5:41 am
If you plan to use a 3/8th anything to undo it, you'll only stuff it further.
It's a 10mm metric square drive.
Post Posted: Tue Jun 28, 2011 5:46 am
yeah i havent even touched this and its been totally butchered by the previous guy not even a brand new 10mm will do anything
hmmm may need to use a small cold chisel and tap it around
i don't wanna use an easy out as i don't want to run the risk of metal shavings getting into the transfer case
Vehicle: SJ80, SE416
Post Posted: Tue Jun 28, 2011 6:18 am
Kincrome make an 11mm sq. sump tool. My vit had well rounded drain plugs so I bought one of these and ground off 2 edges with a grinder to make it about 10.2mm and used a hammer to get it in the rounded hole firmly. Then I used a breaker bar to remove the 'tight as' plug.
Post Posted: Tue Jun 28, 2011 6:59 am
:helloo:
Don't use an easy out, Satan him self made those thing's....
Post Posted: Tue Jun 28, 2011 7:12 am
yeah very aprehensive using one - think i might just use the cold chisel instead
Post Posted: Tue Jun 28, 2011 7:20 am
A bit of Rostoff Ice might help your cause??? its a product Wurth Make... ( work pays for our stuff thank christ ) its not cheap, but it helps getting Loader Bolts undone ;)
Stocker
Post Posted: Tue Jun 28, 2011 7:28 am
:helloo:
yes they can be dogy lol when they brake its a very bad thing haha
Post Posted: Tue Jun 28, 2011 8:19 am
:helloo:
yes they can be dogy lol when they brake its a very very very very very very very very very very very very very very very very f*#ked up thing haha
:helloo:
Post Posted: Tue Jun 28, 2011 8:29 am
i just checked no 10mm tools on ebay.
Post Posted: Tue Jun 28, 2011 8:39 am
:helloo: what flavour do you want phill
http://cgi.ebay.com/ebaymotors/8mm-10mm ... 53e801c219
http://cgi.ebay.com/ebaymotors/8MM-X-10 ... 3a6007a8dc
http://cgi.ebay.com/ebaymotors/8MM-X-10 ... 3a6007a98c
i have the top one & they're a good fit.
Vehicle: LJ20 LJ50
Post Posted: Tue Jun 28, 2011 8:42 am
He must have been on ebanned looking for 10 mm tools. I think on that website they start at around 4 ft long don't they jenzel jnr?????
http://www.ebanned.net/
Camels have nice toes
Vehicle: LJ20 LJ50
Post Posted: Tue Jun 28, 2011 8:49 am
http://shop.ebay.com.au/?_from=R40&_trk ... Categories
and here about 10 different ones from australia including 11mm ones triangle ones and others
Post Posted: Tue Jun 28, 2011 8:53 am
cut a nothc with a dremel tool (and grinder bit) the get a impact driver on it?
THINKING BEFORE POSTING!!!
Post Posted: Tue Jun 28, 2011 9:03 am
I just welded 19mm nuts to all mine
Post Posted: Tue Jun 28, 2011 9:39 am
for some reason none came up.. thanks bought one :D
Post Posted: Wed Jun 29, 2011 10:38 am
ok so cold chisel isn't working so im thinking maybe doing the notch and impact driver idea? How much are impact drivers these days?
Users browsing this forum: Google [Bot] and 215 guests
