It is currently Sun Jul 26, 2026 7:48 pm
Post Posted: Wed Jun 29, 2011 1:45 pm
Hi all.
Already have a 2" suspension lift in my 92 LWB vitara.
Want to go another 2" higher as I have 30" tyres that sometime scrub.
Should I go that extra 2" by using a coil spacer or by doing a bodylift?
Price isn't an issue and neither is fitting as I like messing around with my cars.
Just purely want to know which is the better option and the advantages and disadvantages of the two.
Do coil spacers flog out cv's or any other components?
Also, I know that I would lose shock travel with a coil spacer so in that regard, would a bodylift be better?
Thanks so much for any help!
Post Posted: Wed Jun 29, 2011 2:29 pm
if money isnt an issue go with a calmini lift then BL if you still have issues
Post Posted: Wed Jun 29, 2011 3:07 pm
assuming you want to keep your current suspension, body lift is the better option imo.
but remember a body lift only lifts the body to fit bigger tyres, no extra clearance is gained on the chassis. some people prefer to chop the guards over a bl
Post Posted: Wed Jun 29, 2011 7:42 pm
I think I wouil prefer to to do a bodylift. If you go with a 50mm and a 30mm coil spacer would that create any problems or strain on components?
Post Posted: Wed Jun 29, 2011 8:41 pm
The cv's would be on a higher angle.
Post Posted: Wed Jun 29, 2011 9:21 pm
Just put some bump stop extention on and do a bit of hammering
I have 31 with no body lift so 30 would be fine
Where is it scrubbing
Post Posted: Thu Jun 30, 2011 3:21 am
i have 2 inch leaf lift , and 30's but scrubed on front bar just took it off and hammerd some guards up
Post Posted: Thu Jun 30, 2011 5:22 am
If money is really no issue buy the 4.5" AlteredEgo Kit.
No one else has one and they look cool.
Post Posted: Thu Jun 30, 2011 5:37 am
good website have some kewl stuff :) eg jerry can holder :)
Post Posted: Thu Jun 30, 2011 5:39 am
The higher you lift the suspension in anything the worse it becomes to drive, that much in a vit its going to wander in the front a bit
30's arent bih either, look at where its scrubbing and see if you can bash it out the way
Users browsing this forum: Google [Bot], phlix and 88 guests
