| Author |
Message |
dawsey
Joined: Fri Mar 19, 2010 10:30 pm Posts: 218 Location: perth
 Posted: Fri Jul 01, 2011 6:13 am |
Ive just got my rear tail shaft balanced and new uni joints fitted both ends, got it back home , and noticed that both ends are out of phase 90 degrees difference than original..hence no dot realignment..I fitted it took it for a run and no vibration or unis slapping around like before,it drives well..I rang them to ask why the unis are out of phase there response was to disregard the dots as it was balanced the the way it is . Seems a bit odd to me..what do you think ..it does drive good now though. Does it really matter?
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Fri Jul 01, 2011 6:25 am |
Nissan actually run the front shaft on the GU Patrol out of time from factory.
I'm a bit of a stickler for getting the yolks lined up right, just so the uni aren't fighting each other when running big angles.
jmd-247
Joined: Mon Apr 04, 2011 11:24 am Posts: 224 Location: THE BURGH!
 Posted: Fri Jul 01, 2011 6:49 am |
dawsey wrote: or unis slapping around like before,
MIne slap like a bitch!!!
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Fri Jul 01, 2011 9:25 am |
My shafts are cactus at the slip yokes, front one has about 10mm movement up and down if you push on the middle of the shaft!
Can't be good for it but unless I pay the $90 each they want up the road, I have to wait for Jas to get some back in stock! (Or someone to wreck a WT with good shafts)
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Fri Jul 01, 2011 8:18 pm |
I'd be taking it back & asking politely to balance it with the dot's lined up.
Cause if you remover the shaft & it slips out you have to get it re-balanced again...
_________________ I used to be indecisive,
dawsey
 Posted: Sat Jul 02, 2011 12:54 am |
steak_knife wrote: I'd be taking it back & asking politely to balance it with the dot's lined up. Cause if you remover the shaft & it slips out you have to get it re-balanced again...  thats not really a problem with realignment if they separate , they etched in 2 arrows on both shafts and painted them white..I will drive it for awhile then see..
steak_knife
 Posted: Sat Jul 02, 2011 1:42 am |
Still an ass about way to do a balance...
dawsey
 Posted: Sat Jul 02, 2011 1:49 am |
steak_knife wrote: Still an ass about way to do a balance... yep, not what I woulda done
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Sat Jul 02, 2011 2:42 am |
Not really, rover also done this from factory. When a u-joint works, the output speed becomes the same as the input speed but it is not a smooth power transfer. The nature of the beast will cause it to accelerate twice and de accelerate twice (torsional vibration) through a rotation and thus average out to the input speed. This torsional vibration gets worse with increase u-joint angle.
I think what happens when you put the yokes out of phase you end up with one acceleration and one deceleration term at higher u-joint angles thus producing less torsional vibration or something like that.
End line: There is a perfectly logical reason for balancing it like this
_________________ Lil Foot!
http://tiny.cc/gtsw1
