It is currently Sat Oct 10, 2026 3:38 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2  Next
Post Posted: Fri Jul 08, 2011 8:38 am
Hey all... my diffs doing a nice thud when i let the clutch out, its definitely gotten worse over the last few weeks and happens in any gear if i let the clutch out medium/fast.
Grabbing the rear tailshaft theres a ton of play in the pinion, and jacking the rear in the air i can move the wheels slightly left/right and up/down, only very slightly, but when i do it clearly moves the axle (can hear it).
Rear diff hasnt been touched for 4 years since it had an airlocker installed, unis are new and no play.
Anyone got a diagnosis for me before i take it in on monday to get a proper opinion? (ie: strip it down).
Post Posted: Fri Jul 08, 2011 8:41 am
any bearing that moves in the rear is rooted
Vehicle: 2004 KJ jeep cherokee
Post Posted: Fri Jul 08, 2011 8:43 am
bearings be fooked, take it to a diff specialist and get the to check it compleatley.
If at first you don't suceed... lower your standar
Post Posted: Fri Jul 08, 2011 8:44 am
hope so - i'd rather it be a bearing than anything with teeth... im afraid its a worn crownwheel...
Post Posted: Fri Jul 08, 2011 8:45 am
st1ll a b1g j0b
Post Posted: Fri Jul 08, 2011 8:46 am
Follow up question - if i baby it (gentle on the clutch) is it going to survive doing 100km/hr for 45 mins, then about 3-5 hrs of low range crawling, then another 45mins of 100km/hr? before i take it in on monday? =)
Post Posted: Fri Jul 08, 2011 8:51 am
haha you should know that the only way to find out is to have a go.
Post Posted: Fri Jul 08, 2011 8:55 am
i plan to =) its been doing the clunk for ages now so i can't see it failing catastrophically on me (famous last words?)
Post Posted: Fri Jul 08, 2011 8:57 am
if its from the gears - might break em on your trip
if its from bearings - probably be ok
Post Posted: Fri Jul 08, 2011 9:11 am
If the bearing is rooted, then the pre-load on the bearing will effect the backlash between the crownwheel and pinion. I wouldn't drive it Arron, you're going to fruck it good and fast.
helloo
Post Posted: Fri Jul 08, 2011 9:14 am
when you say fruck it... am i going to do more damage than whats already been done? =)
Post Posted: Fri Jul 08, 2011 9:16 am
if a diff bearing collapses it will more likely then not take out the crown wheel and pinion as well.
Post Posted: Fri Jul 08, 2011 9:17 am
You could chip teeth off the crownwheel, the pinon and crownwheel are going to mesh wrong. I wouldn't risk screwing my airlocker for a few days driving.
helloo
Post Posted: Fri Jul 08, 2011 9:22 am
bugggerrrrr... hmmm.
Post Posted: Fri Jul 08, 2011 9:58 am
Mine does this wear would I get new bearings. Im about to fit spartan locker so might as well do bearings. Anyone got a write up on changinv bearings?
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Fri Jul 08, 2011 10:13 am
how long has yours been doing it for? lol
Post Posted: Fri Jul 08, 2011 10:20 am
if you need to ask then I don't think you should be attempting a spartan. Haha, you are gunna need a puller to get the carrier bearings off.
helloo
Vehicle: 03 Jimny
Post Posted: Fri Jul 08, 2011 10:29 am
My rear diff did the same as you explained
I drove over 6 months like it was, but was no heavy 4wding neither did I have big tyres like yours
Post Posted: Fri Jul 08, 2011 11:49 am
Bout 3 weeks ago it started becoming noticable. No one in coffs wants to do my locker as they keep tellin me there dodgy. So no choice but to have a crack.
Im no mechanic but the old man is pretty good at it and a mates a mechanic sure
We can figure it out.
Lockie we have a bearing puller.
Post Posted: Fri Jul 08, 2011 11:53 am
just baby it, check the oil for a start,
if its a bearing it could collapse which means removing the rear shaft and driving it 4wd worst comes to worst u breack a tooth other wise its just needs some tlc t
dodgy brothers mechanical
Post Posted: Fri Jul 08, 2011 12:32 pm
This is the worst advice someone can give. The diff will be spinning regardless of there being a tailshaft or not. Please refrain from talking shit. Arron, just get it fixed mate, you will end up blowing your diff. You don't want to blow your diff on the road and having your rear lock up on the road. Its not cheap getting another center, pinon, crownwheel. You also run risk of fucking the housing too... Just expressing my opinion
helloo
Post Posted: Fri Jul 08, 2011 12:42 pm
x2 Lockie!
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri Jul 08, 2011 3:32 pm
x3
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Fri Jul 08, 2011 10:09 pm
for a bloke who is supposed to works in a 4x4 workshop/store you know sweet fuck all about cars.
dont listen to noob boy, the inside end of the axle is supported by your diff bearings. so if you blow the diff the axle isnt going to turn real well is it.
dont baby it because they always break at the best times just fixit while its still relitively cheap
edit: I see someone else X 3 have said the same thing. just fix it
Post Posted: Fri Jul 08, 2011 10:19 pm
Mines been clunking and whining for 50000km, bearings can handle a fair amount of abuse :)
Post Posted: Fri Jul 08, 2011 10:51 pm
My front is the same as yours alien. I'm swapping a new one in today!
But i'm lucky its in the front..
Post Posted: Mon Jul 11, 2011 9:43 am
ok so i drove on the weekend and went 4wding for this photoshoot i had planned, just took it easy and babied the diff (rode the clutch a little more). Went fine all day, very proud of my sierra given what i've just found out!
diff was stripped today and so far my damage list is:
- 1 rear wheel bearing (replacing both obviously)
- both rear axles (short side is twisted and fractured, long side is fractured)
- diff bearings are a combination of buggered and on their way
- replaced rear shoes while its all out
will update if anything else is discovered by the diff specialist =)
Post Posted: Mon Jul 11, 2011 10:04 am
suzistore do my diffs, much cheaper and better than other diff shops in perth, at least u know an apprentice isn peicing it together too :wink:
Post Posted: Mon Jul 11, 2011 10:07 am
haha nar mines being done by a pro, and he knows airlockers very well... he is also cost effective.
Sean (suzistore) is on holidays for a week so suzistore wasnt an option.
i do my own :?
Users browsing this forum: No registered users and 276 guests
