is it possable that they forgot to add a bit of loom your after as with some of the cars ive worked on they have a few bits to it best to check out a running motor and see where bits go so you know if there is anything missing
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
Posted: Mon Jul 11, 2011 11:28 am
Are there any pins in the connector? there is a sprung tab on the pin that must be pushed back to slide the pin out. You could then use pins from another similar connector. A replacement connector would still be the best option, I domn't know what the rest of the wiring is like but its agodd idea to keep the original wire colours to make fault-finding easier.
Users browsing this forum: Google [Bot] and 121 guests
