It is currently Thu Oct 08, 2026 8:03 am
Post Posted: Thu Jul 14, 2011 11:32 am
Hi Guys i have a 1992 SJ70 and am putting 6.5:1 reduction gears in with updated output shaft and a full rebuild....
I have a good mechanical knowledge and was wondering if any 1 could tell me how hard rebuilding the case actually is before i go pulling it apart!!
any help would be greatly appreciated .... Cheers
Vehicle: 4wd
Post Posted: Thu Jul 14, 2011 11:34 am
It's very straight forward, as long as you have the right tools.
Watch out or you'll get sued.
Post Posted: Thu Jul 14, 2011 11:35 am
go to the lowrange website and look at the 651 and there should be a link to a good install with pics and everything
if u drive a loud toyota ute u drink rum
Post Posted: Thu Jul 14, 2011 11:36 am
Ok then.. i got a pretty full shed, what sort of speciality stuff is required??
i can my hands on most things when needed cheers
Vehicle: '96 LWB trayback
Post Posted: Thu Jul 14, 2011 11:39 am
Having never seen one done before I was 100% hesitant to tackle mine.
31zook generously ended up rebuilding it for me while I looked on.
If you follow the instructions it's very much idiot proof. I wouldn't hesitate to crack mine open and do it tomorrow now.
Just make sure you've got all the tools you need to do the job first. ie: gear puller, hydraulic press, thickness gauge, shim paper, sealant etc.
Post Posted: Thu Jul 14, 2011 11:55 am
Cheers guys just got it then easy as :) Thanks for all your quick help :)
Vehicle: Daisy
Post Posted: Thu Jul 14, 2011 9:05 pm
Just remember if you attack that small cage bearing in the end of the shaft, be prepared to see it through...
Apparently you can get a gear/bearing puller that is small enough to do the job though so this may be handy!
Vehicle: 4wd
Post Posted: Thu Jul 14, 2011 10:16 pm
:? They slide off.
Users browsing this forum: No registered users and 184 guests
