It is currently Sun Oct 04, 2026 7:04 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
Vehicle: Yamaha scooter, 50cc
Post Posted: Thu Jul 28, 2011 10:27 pm
Can anyone tell me what size socket I need to change the front wheel bearing on a 93 sj70 Sierra? Any other tips and tricks for changing without workshop tools would be appreciated too
Vehicle: Yellow Ute
Post Posted: Thu Jul 28, 2011 10:43 pm
By that are you talking about the massive nut? I just used a blunt coal chisel and a couple of whacks got it started just be careful when you undo it if you use your fingers they are bloody sharp nuts... So pretty much just spanners, I think the newer sierras have a circlip that doesn't need circlip pliers just two screw drivers, coal chisel and a hammer... Also make sure you do the nuts up tight enough... :oops:
One problem I had was when I went to put (now I don't know what it is called but it is like the spacer thing under the hub lock bit that holds the other wheel bearing) that bit back on the cv would slide in a bit and I didn't notice for a while and I couldn't get the circlip back on.
Post Posted: Thu Jul 28, 2011 11:17 pm
If it is the massive nut in the free wheeling up that holds the outer wheel bearing inplace, then it would be a 50mm. Its a tad awkward to find a 50mm tube socket, but if you can get the 54mm one that does hilux wheel bearings that works (I have a 54mm one, thats how i know) its not ideal but for the frequency of use, it gets my by. ALSO, it helps having the socket cause then when you are doing the nut back up it help get it tensioned right.
There is this, but the postage is a bitch
http://www.ebay.com.au/itm/Laser-Socket ... 5d2e5c90ba
Post Posted: Thu Jul 28, 2011 11:41 pm
Cheers guys, I'm trying to do it at our campsite right now with basic tools, but do have access to a repco close by.
Post Posted: Thu Jul 28, 2011 11:42 pm
Also how do you press the bearings on and off without a press??
Post Posted: Thu Jul 28, 2011 11:49 pm
Don't need to press the front bearings!
My Maruti build, Click WWW
I've never used apress for sierra front wheel bearings. Use a square edged drift and strike the outer bearing race from behind, alternating positions so that it comes out straight.
To replace, Tap in gently with the same method ( better if you have a copper mallet handy )
Post Posted: Thu Jul 28, 2011 11:55 pm
Awesome thanks guys
Post Posted: Fri Jul 29, 2011 12:22 am
You can actually use one of the 6 bolts that hold the swivel hub on. It screws into the end of the CV and you can just pull it out so you can put the circlip back on it.
Vehicle: Yellow Ute
Post Posted: Fri Jul 29, 2011 12:55 am
Would have never noticed that... Thanks for the tip.
Post Posted: Fri Jul 29, 2011 1:28 am
Rum inspiration. I found out by the good grace of the bundy bear.
Post Posted: Fri Jul 29, 2011 8:40 am
Do it properly. Use a torque wrench and a 50mm socket and set them up as per the FSM, to torque. The required torque on the outer nut is MUCH higher than you'd imagine and much higher than you'd achieve by feel.
They are surprisingly reliable when set up by torque, even with big tyres.
Using a cold chisel might be acceptable to loosen them, not to re-tension them.
I bought a 50mm socket and 3/4 to 1/2" adapter from Repco for not that much money years ago.
You don't need a tube socket, although it helps. I pull the spindles off and do the bearings on the bench though rather than on the car - much nicer job on the bench.
Post Posted: Fri Jul 29, 2011 9:20 am
This was a trackside repair steve. I'm sure he will re-visit them when he is back home again. :wink:
Post Posted: Fri Jul 29, 2011 9:24 am
bohuler wrote:
http://www.ebay.com.au/itm/Laser-Socket-Specialist-50mm-1-2D-3380-/400209776826?pt=LH_DefaultDomain_3&hash=item5d2e5c90ba
You sure that's deep enough?
Been trying to find one for a while as well.
Post Posted: Fri Jul 29, 2011 10:15 am
Dunno if its deep enought, there was another deep impact socket on ebay but it was a 3/4 drive one so you'd need the 3/4 to 1/2 inch adaptor and being a deep impact socket its more expensive. It was just a quick search to show whats avalible :D
Dave
Post Posted: Fri Jul 29, 2011 11:06 am
bruce get one from the caboolture markets for about 10 bucks. thats where I got mine.
Post Posted: Fri Jul 29, 2011 10:06 pm
I wasn't passing comment on anyone in particular. Every car I've ever pulled apart has had the bearings done by cold chisel and feel, and lots of people think that's a perfectly acceptable way all the time.
Post Posted: Fri Jul 29, 2011 10:24 pm
From memory my socket and adapter cost me about $40, though i'd be suprised if you couldn't get it cheaper these days. I'm in the "get the right tools and do it right" camp on this one!
I've always done the bearings on the vehicle. Next time i'll try it on the bench, thanks for the tip Steve!
Post Posted: Fri Jul 29, 2011 10:25 pm
i did mine properly with a torque wrench and they haven't been touched for over 3 years and a shitload of km.
from memory ya tighten them to 50lb then back them off to 0lb then re-tighten to 10lb
i have a lowrange hub nut socket, was cheap and works well
Post Posted: Fri Jul 29, 2011 10:33 pm
That's about it for the inner nut, but the outer nut has lots of tension on it.
I'll be doing the hubs for the floater on the rear of the tug today/tommorow.
Vehicle: Yellow Ute
Post Posted: Fri Jul 29, 2011 11:49 pm
Excuse to go get stuff. :P
"But mum Gwagensteve said I need one"
Post Posted: Sat Jul 30, 2011 12:34 am
Like we need excuses to buy new tools 8)
Vehicle: Daisy
Post Posted: Sat Jul 30, 2011 12:38 am
Going to have to look into this "doing them on the bench" method, I haven't even got them to do them yet but it already sounds easier :p
Post Posted: Sat Jul 30, 2011 6:47 am
Just did them - from the FSM:
First nut up to 90Nm( 8O ) whilst turning the hub
Back off to 0Nm
Torque up to 15Nm
Lock ring on
Outer nut to 80Nm
1-3Kg of starting torque with a fish scale on the studs is the acceptable range.
Vehicle: Daisy
Post Posted: Sat Jul 30, 2011 8:02 am
Back off to 0Nm
Torque up to 15Nm
Lock ring on
Outer nut to 80Nm
Fish scale as in the kind you hang a fish off to measure it's mass?
Post Posted: Sat Jul 30, 2011 8:07 am
Yep. I don't have one so I guess starting torque - but it's a fairly wide range you are aiming for so I think it's fair enough to guess. There's no good reason I don't have one.
Vehicle: Daisy
Post Posted: Sat Jul 30, 2011 8:21 am
For all that matter you could use a 1-3kg mass on the end of a string and provided it turned on it's own when you let it go you're in range :)
Wouldn't be hard to find a bit of string/rope and something that weighed between 1 and 3 kg!
Or just go buy a fish scale I suppose!
I guess now that I've located new drive shafts, I should send weaves an email and get the bearings and seals ordered, then everything will be good till the engine swap/zook rebuild
Post Posted: Sat Jul 30, 2011 8:25 am
2L orange juice/ milk bottle =D
Vehicle: 2018 DMAX
Post Posted: Sat Jul 30, 2011 9:01 am
A pull scale is all of about $15 from BCF if you want todo it correct... But in saying that i just guess..
Vehicle: Daisy
Post Posted: Sat Jul 30, 2011 10:45 am
Ding Ding Ding, we have a winner!
I was thinking cordial bottle, but that's because I had/have one sitting beside me!
Macgyver would be proud!
Users browsing this forum: Google [Bot] and 201 guests
