It is currently Fri Oct 02, 2026 9:01 pm
Post Posted: Thu Aug 04, 2011 6:17 am
Howdy fellas,
Well, let me start by saying I am no mechanic. Some of you might remember another thread I did when I changed my girlfriends clutch.
Now, I haven't seen a billion flywheels before; But I have seen enough to know this looks kinda funky :crazy:
The whole between the dowel and threaded hole on the bottom half is what I am concerned about. Maybe concerned isn't the right word, more intrigued as to what its caused from.
It doesn't look like a machined finish.
Share your wisdom
Post Posted: Thu Aug 04, 2011 6:19 am
original balancing holes from when it was cast?
Post Posted: Thu Aug 04, 2011 6:25 am
The two big holes are where weight has been removed to balance the flywheel.
Likewise with the hole between below the dowel and above the threaded hole.
The other bits are just casting imperfections.
None of it is any cause for concern.
:youdaman: yess!!
Post Posted: Thu Aug 04, 2011 6:29 am
Haha cheers guys. I had never seen them before. Always keen to learn new things.
It seems that all the weight has been removed from one section. do they warp or anything like that?
Post Posted: Thu Aug 04, 2011 6:33 am
it's done to balance to the rotating mass of a motor, a balanced engine that has been built properly will have those sort of random drill marks from the crank shaft pully right thru to the clutch pressure plate. including each piston, conrods & crankshaft.
the result is a smoother & better revving engine
Post Posted: Thu Aug 04, 2011 6:47 am
Are they balanced to a specific engine. I.E could this be put onto my engine and throw it out of balance?
Post Posted: Thu Aug 04, 2011 11:09 am
swifty_ano wrote:
Are they balanced to a specific engine. No
I.E could this be put onto my engine Yes
and throw it out of balance?No
Users browsing this forum: Google Adsense [Bot] and 117 guests
