It is currently Fri Oct 09, 2026 5:57 pm
Vehicle: 85.Ruf. rear air locker
Post Posted: Sun Aug 07, 2011 11:47 am
Hey guys
Does any one know what this problem is ?? my brakes are soft but when u pump them they go hard.
I have bleed them several times but it doesnt help at all
Post Posted: Sun Aug 07, 2011 11:50 am
supa_slim wrote:
Hey guys
Leak in the braking system?
My LJ80 did this after I first got it running. Eventually had the master cylinder rebuilt as it was drawing in air through it.
Clearance Hole Technology :P
Vehicle: Sj70 tintop
Post Posted: Sun Aug 07, 2011 11:58 am
maybe master cylinder? but a leak sounds likely.
Sj70 tintop
Post Posted: Sun Aug 07, 2011 12:00 pm
Great that will be fun to find
Do u think it would be the master cylinder
Post Posted: Sun Aug 07, 2011 12:02 pm
are you loosing fluid?
Post Posted: Sun Aug 07, 2011 12:05 pm
Yeah i am not a lot but
I think i comes out of the filler cap though
if your not losing fluid, thats what i would start looking at, but im far from an expert on brakes...... or much at all. lol.
Sj70 tintop
Post Posted: Sun Aug 07, 2011 12:08 pm
Ive check under the car to see if i could see any leaks but i cant see any
Post Posted: Sun Aug 07, 2011 12:11 pm
I would think if it was leaking bad enough to feel it in the pedal you would be topping up the res daily.
Post Posted: Sun Aug 07, 2011 12:13 pm
So do u guys think it is the master cylinder then
Post Posted: Sun Aug 07, 2011 12:14 pm
Other common place to check would be your drum brake slave cylinders on the back. Just pull the drums off, and see if there is any sign of a leak in there.
Post Posted: Sun Aug 07, 2011 12:15 pm
keep the handbrake adjusted up and you will be fine :steamroller:
Post Posted: Sun Aug 07, 2011 12:16 pm
good chance, but check it all out to be sure :wink:
Post Posted: Sun Aug 07, 2011 12:18 pm
Ok ill do that highway star
Post Posted: Sun Aug 07, 2011 1:13 pm
clamp off 1 soft line at a time, that will help you locate problem.
Post Posted: Sun Aug 07, 2011 1:46 pm
whenever my brakes get spongy my rear shoes are low on meat... i go through rear shoes about every 6-9months!
Post Posted: Sun Aug 07, 2011 6:35 pm
x2 I just had the same issue and got new shoes and the problem was sorted.. Check rear shoes.
Post Posted: Sun Aug 07, 2011 8:57 pm
I changed mine about 7 months ago
I'll have a look tonight
Post Posted: Mon Aug 08, 2011 7:16 am
Having similar problem, my zook had soft brakes which got harder if you pumped the pedal a few times, one time last drive after a steep downhill they felt very touchy and firm like they should, that went away pretty quickly though. they are not leaking fluid anywhere, and i had it parked for 2 weeks and then fitted new pads on weekend in front end so pressed the caliper piston back and now they wanna go to the floor first touch you can pump them up and they feel better but soon as u drive the pedal goes to floor again. if you pump the pedal it feels like the engine wants to stall when idling. i have bled them twice now with no success.
any ideas??
Post Posted: Mon Aug 08, 2011 7:18 am
S_M_I_D_D_Y wrote:
Having similar problem, my zook had soft brakes which got harder if you pumped the pedal a few times, one time last drive after a steep downhill they felt very touchy and firm like they should, that went away pretty quickly though. they are not leaking fluid anywhere, and since last weekend i had it parked for 2 weeks and then fitted new pads in front end so pressed the caliper piston back and now they wanna go to the floor first touch you can pump them up and they feel better but soon as u drive the pedal goes to floor again. if you pump the pedal it feels like the engine wants to stall when idling. i have bled them twice now with no success.
any ideas??
rear brakes shoes. is the handbrake shit too?
when ya comin' over!! :helloo:
Post Posted: Mon Aug 08, 2011 7:30 am
gday mate. yep well im tearing rear diff apart tomorrow, so will check those out then. just waiting on the mrs to turn up and ill head out
Post Posted: Tue Aug 09, 2011 10:43 am
HaD a look at the rear brake shoes Tonight and they are rotted..
Post Posted: Tue Aug 09, 2011 11:38 am
yay!
Users browsing this forum: No registered users and 122 guests
