It is currently Sat Oct 31, 2026 8:20 am
Post Posted: Tue Aug 09, 2011 8:14 am
Hey guys im looking at giving my stock 88 WT sierra a 2'' suspension lift and possibly body lift (only if tire clearance becomes an issue) for under $1000
I had a look at the tech thread with the 2'' ome lift using commodore shocks and hiace shocks, which is the direction i was looking at going, but which year commodore and hiace shocks are the shocks to use?
Ive been to ARB today and was qouted $1100 for the 40mm OME lift, for the full kit including bushes, ubolts, OME shocks etc..... but really its not 2 inch its only 1.5", i want 2" at least!!!
So just wondering what other options are available for a cheap lift?
and what opinions to people have on getting leafs reset?
Post Posted: Tue Aug 09, 2011 9:04 am
That tech thread should have the part numbers for the Gabriel shocks that you need to get. Dont worry about the years just take those numbers into Supercheap and give them the part numbers.
I wouldnt get the stock springs reset 2 inches higher it would make for a fairly short spring giving a pretty harsh ride I imagine.
Post Posted: Tue Aug 09, 2011 11:38 pm
Along with the 2" OME suspension lift and gabriel shocks.....2" body lift is pretty cheap which you can buy brand new from this site
Vehicle: 03 Jimny
Post Posted: Tue Aug 09, 2011 11:50 pm
The 40mm ome springs is enough I reckon. I run them plus a 2inch body lift and it's bloody high
Post Posted: Wed Aug 10, 2011 12:02 pm
cheers guys, went and got a qoute from an industrial spring making company to get some 2'' springs made and they were over $600 for the springs alone so i think im gonna have to go with the OME/gabriel shocks option, then most likely body lift
Vehicle: 03 Jimny
Post Posted: Wed Aug 10, 2011 12:18 pm
what size tyre are you plan on running
Vehicle: Ducati Monster
Post Posted: Thu Aug 11, 2011 1:40 am
give dank a buzz, he is clued up on suspensions, nice fella too..........
Post Posted: Thu Aug 11, 2011 2:15 am
40mm spring and 2" body lift is heaps.
Post Posted: Thu Aug 11, 2011 6:46 am
not sure exactly what tires im gonna run but defiantly no bigger than 30''
Vehicle: 03 Jimny
Post Posted: Thu Aug 11, 2011 6:57 am
then you wouldnt need body lift at all.
i run 30's and theres shit loads of room
i would just get a 40mm lift, gabriel shockies and bumper stop extensions to minimize scrubbing, or just cut/ hammer your guards IMO.
Post Posted: Thu Aug 11, 2011 7:01 am
x2. Spring and about 25mm extended bumpstops.
Post Posted: Thu Aug 11, 2011 7:12 am
i was under the impression that 30s would scrub a shitload without BL?
will be ordering springs/shocks tomorrow
any tyre ideas?
girlfriend just had KL71s put on her vitara and they look good but haven't tested them off road yet.
was also thinking about insa turbos
just looking for possible ideas ATM
Post Posted: Thu Aug 11, 2011 7:20 am
Nope. I have 31's on a 2" lift with 30mm bumpstop spacing. Doesnt touch.
Post Posted: Thu Aug 11, 2011 8:09 am
i have ome 1.5" and a 1" b/l and my tyres just are scrubbing when on bumpstops, thats with 31's.
My Maruti build, Click WWW
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Aug 12, 2011 1:10 am
You just need a hammer and some bump stops.
I had 25mm bumpstop extensions on 31s, cristovers old OME springs front and rear for a while, then I put my OEM rears in the front.
Post Posted: Fri Aug 12, 2011 7:47 am
ordered it all today..
OME front springs $81 each
OME rear $111 each
front gabriel shocks $50 each
rear gabriel shocks $45 each
OME bushes $120
ubolts from ARB $75
total $769
for some reason i got all shocks for $45 each + they had a deal buy 3 get 1 free, so i got it for $716
the only thing i didnt think about was the steering damper.. how much difference will a new one make? worth getting one?
Post Posted: Fri Aug 12, 2011 7:59 am
Dont worry about it straight away. You dont need them. They're just nice to have sometimes.
Users browsing this forum: Google [Bot] and 496 guests
