It is currently Wed Oct 14, 2026 11:06 am
Post Posted: Sun Aug 21, 2011 6:09 am
Hey everyone
ive had a 3 inch calmini bidy lift kit for my vitara for over a month now. ive been avoiding putting it on due to lack of experence with a job of this size. If there is anyone local to blacktown that would help me install this lift kit on my vitara That would be great you wont be working for free.. we can negotiate how much it would cost me before we start. Any advice on this would also be very helpful to me. Also im very flexible about were the job is to be done... can be done at my house ( i belive i have all the nessary tools including a welder) or at a location of your choosing.
Thanks to everyone who posts.
Post Posted: Sun Aug 21, 2011 6:27 am
why have you chosen to go 3" BL? is it really needed? a 2" bl is a lot easier to do as less things need to be modified. but since you already have it, its a bit late.
when i installed my 2" bl, it took me and 2 others about 5hrs. does it come with instructions? if it does i would suggest reading them, not after when things go wrong lol. its pretty straight forward to do, but even easier when you have experienced helpers.
good luck.
p.s- we need pics, make a build thread please. :D
Post Posted: Sun Aug 21, 2011 6:52 am
is it a "body" or "suspension" lift ?
Post Posted: Sun Aug 21, 2011 11:02 am
don't waste you time fitting the kit, it's basically junk.
with the time & effort saved in not installing the calmini crap, buy one of just_cruizin. just_cruizin
http://auszookers.com/index.php?name=Fo ... ic&t=15518
realistically the only good bits in the calmini kit is the transfer shifter extension & the fuel filler extension... oh & maybe the instructions cause there are pics. :wink:
i can fit one of just cruizin body lifts into a swb vitara in under 1/2 a day on my own, it's probably a full day or weekend job for a first time.
Post Posted: Sun Aug 21, 2011 11:46 am
Its a Body lift.. i allready have calmini 3 Inch suspention lift installed on my car and yes i do have instructions and i think i know how to do it but i reallly would like it if someone experienced was there to help me out.
Post Posted: Sun Aug 21, 2011 11:48 am
personally i would NOT USE THE CALMINI BODY LIFT & i had one installed.
Post Posted: Mon Aug 22, 2011 4:10 am
i'm not sure on the quality of the calmini body lift but if you have read the instructions and think you can do it give it a go i did the body lift on my old swb patrol by myself in around 4 or 5 hours and i didn t have a kit with instructions .
Post Posted: Mon Aug 22, 2011 5:26 pm
www.CALMINI.com
Post Posted: Tue Aug 23, 2011 12:03 am
The Calmini body lift, is not able to be engineered in Australia due to the construction of the kit. I personally ran one of your body lifts & removed it due to backyard design of the kit.
Post Posted: Tue Aug 23, 2011 12:15 am
Not being able to be engineered in AU sort of sums up the whole thing IMO.
Sorry Calmini, never had anything to do with your products, but it is pretty important to sell or buy car parts that are engineering legal.
Vehicle: SJ50 hardtop!
Post Posted: Tue Aug 23, 2011 12:16 am
Not everyone is looking to run "engineered" vehicles.
Look at how many cars here probably wouldn't pass engineering.
NT SJ50
Post Posted: Tue Aug 23, 2011 12:18 am
So no one should sell bigger then 35" tyres in Australia, because they aren't engineering legal?
NT SJ50
Post Posted: Tue Aug 23, 2011 12:20 am
ITs alot easier to swap a set of tyres to go over the pits than it is to pull a body lift out though dont that think?
Post Posted: Tue Aug 23, 2011 12:24 am
So you should run something illegal till it has to go over the pits??
Sounds like your fine to run the 3" body lift then, Luka!!
NT SJ50
Post Posted: Tue Aug 23, 2011 12:30 am
Bucket, most vitara drivers are able to use their car as daily's coz theyre far better onroad than a modded sierra :wink:
Ask the original poster first if its a daily.
Post Posted: Tue Aug 23, 2011 12:32 am
Just wondering, whats that going to change?? I ran 5" lift with 32" and a deep neg offset for ages. Not the most comfortable ride onroad but never any trouble from the popo, and I didn't run flares on the rear either.
NT SJ50
Post Posted: Tue Aug 23, 2011 12:46 am
Mine probably wouldn't pass engineering due to the body roll, but at least the bodylift would if required. the other thing is piece of mind, knowing there isn't almost twice as many fasteners attaching the body to the chassis.
The kit is made up from a collection of random parts, the polly 3" blocks at the front doesn't appear to have crush tubes, then the remainder of the captive studs are cobbled together with a mix match of parts, metric & imperial bolts, 1/2"x1/2" box section & a separate alloy spacer on top of that. You bolt the box section to the & then the spacer & stud bolt to the top surface of the box section, no crush tube or anything. As I said earlier the good bits are all the little parts that come with the kit.
Calmini Vitara Body lift looks like this.
Post Posted: Tue Aug 23, 2011 12:57 am
I could be wrong but dont new south welshman have to get their car checked at rego time? Blacktown is nsw? And 3" bodylift wont pass?
Post Posted: Tue Aug 23, 2011 12:59 am
Yep, but anything can be passed if you know where to go.
NT SJ50
Post Posted: Tue Aug 23, 2011 1:36 am
Still, getting it passed with a questionable roadworthy doesn't make the design of the kit a good thing. :wink:
Post Posted: Tue Aug 23, 2011 2:13 am
Anyway, since nothing usefull has been said other then a lot of slander, I stick by my PM and will get back to you sometime this week if you haven't gotten it installed already.
NT SJ50
Post Posted: Tue Aug 23, 2011 2:22 am
I tire of you and your attitude, please point out all cases of slander in this thread.
Infact, point them out in the entire forum!
Post Posted: Tue Aug 23, 2011 2:56 am
All this talk is funny,
My LWB had a 3" body lift in it for around 8 years before I sold it and it was made of box section.
It was engineered and legal.
It was made of alot bigger and stronger box section than the Calmini one but was the same concept. It had no signs of ever coming apart.
The SWB that we used to compete in had the Calmini 6" combo, no one here can deny that it was a top bit of kit and copped more punishment in its short life than most of your cars will ever see.
The body lift that Calmini supplied never failed, however what did fail was the mounts on the chassis and the body itself, both of which bent and tore to leave the car with about a 2" lift when we pulled it apart.
Its not the type of body lift that is the problem it is a body lift itself that can become an issue. Even a solid block lift is a bad idea unless you put more bracing in the body itself. If I can help it I will never put a body lift in a car again.
Post Posted: Tue Aug 23, 2011 7:46 am
Post Posted: Tue Aug 23, 2011 7:50 am
Post Posted: Tue Aug 23, 2011 1:17 pm
Well, that seemed to shut the fuck up out of the all knowing and illegal man.
I can get 35s engineered, please explain.
On a zook.
Vehicle: Hard Top Fusty Ducker Vitara
Post Posted: Mon Aug 29, 2011 7:42 pm
Hey all. Not totally on the topic but I'm thinking about buying the 3' calmini suspension lift. How is it goin on your rig? I've heard the munroe shock's that come with it can be prone to failing. Is this correct?
Post Posted: Tue Aug 30, 2011 6:25 am
I don't think they are munroe shocks... they are plain White shocks that come with a calmini Sticker set... not sure where they source them from...
I have Bent one of my Front struts already. and Blown one of the Seals in the back... Not overly happy with the Shocks/Struts, but the rest of the kit is gold :) Its a great starter anyway
Stocker
Users browsing this forum: No registered users and 359 guests
