It is currently Sat Oct 03, 2026 12:02 pm
Post Posted: Thu Aug 25, 2011 9:40 am
Hi All,
Just after your thoughts, good, bad and otherwise about a brake upgrade. The plan is Vit LWB calipers and rotors with the following goodies from lowrange
http://www.lowrangeoffroad.com/index.ph ... -kits.html Will probably get the hard lines made up locally, postage due to size might cost a bit :cry:
http://www.lowrangeoffroad.com/index.ph ... e-kit.html
http://www.lowrangeoffroad.com/index.ph ... lines.html (the 3 hose kit I presume)
Rusho
Post Posted: Thu Aug 25, 2011 9:57 am
pretty much what i have except i have a BenT kit and ebay portioning valve
and i will make my own hard lines.
wont be long and i will let ya know how it goes.
Post Posted: Thu Aug 25, 2011 10:01 am
Are US DOT lines approved in Australia?
the hard lines will get damaged in transit, a few trips back and forward to a local brake shop will get your lines sorted out
the brake doova is illegal and prob not needed with big front brakes
I like BenT's kit
Post Posted: Thu Aug 25, 2011 10:07 am
Good point Royce :wink: Is it just the adjustable proportioning valve that is a no no??
Do you have the full kit Shep??
Post Posted: Thu Aug 25, 2011 10:09 am
If you had of been interested earlier, i had a set of snake racing rear disc conversions up about a month ago, but seeing no one was interested in them, im doing the same conversion on my car.
I would be hesitant buying the hard lines from america before pricing them getting done here, cause with the vit lwb calipers you don't need the proportioning valve (save some $$). Brenno from tas bought the lines and valve from usa so ask him about the quality and his happyness with the system. The other thing is ask B4T about the subaru forester master cylinder upgrade :D
ALSO, if you happen to find LWB vitara calipers and there is a second set floating around, send them my way cause no-ones selling me them :D
Dave
Vehicle: 03 Jimny
Post Posted: Thu Aug 25, 2011 10:14 am
I'm at the stage of finishing of my disc conversion.
Ive got bent kit, really good product :D
Since mine was a nt with two lines going to the rear, I had to change the little silver block below the brake boster to a different one so it's a single line going to the rear. I got a t-piece on the rear diff with hard lines going to each caliper.
Also fited a lowrange proportioning valve.
Yours is a wt so will be a lot less hassle then I had.
I would get bent kit, instead of lowrange
Post Posted: Thu Aug 25, 2011 10:17 am
Dave
www.autoparts.com.au
i got 6 replies in an hour after asking for some calipers...
what you need is LWB vitara disc and calipers in the front, Any off the shelf rear disc kit and Replace your master cylinder with one from a forester. Forester master is alread set for 4wheel disc and has a larger internal bore. 1 1/18 v's 7/8. you need to make a new internal push rod but its all bolt on.
Im sure others will chime in with more details
Vehicle: WR250F/Jeep XJ
Post Posted: Thu Aug 25, 2011 10:18 am
i've just done this on my swb with the TT economy kit. i bought the kit years ago second hand but never fitted off a guy here. I've also installed a subaru forester master cylinder C/- B4T thanks mate!
The proportioning with the subie MC is pretty much spot on. It'll lock up the front and rears pretty much at the same time from around 60km/h. I'm using sierra calipers all round. I'm not using any adjustable prop valve. I also got my brake lines made up at a local brake store, cost me a whopping $35 with a few t-pieces and the flare nuts all in place. I just went in with a coat hanger bent to the shape i wanted and he built it off that.
If you need to do adjustments to the hard lines at home just get something around 50mm diameter pipe and work the line slowly and carefully over the pipe to bend it. If you are careful you will get no distortion in the line at all as it's pretty soft and easy to work with.
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Thu Aug 25, 2011 10:26 am
B4T...what year/model is the forester booster? Do you have any pics of what you had to do??
Post Posted: Thu Aug 25, 2011 10:33 am
dank wrote:
i I also got my brake lines made up at a local brake store, cost me a whopping $35 with a few t-pieces and the flare nuts all in place.
Awsome!! Thats givin me more confindence I can do my conversion onna budget :D
Post Posted: Thu Aug 25, 2011 10:39 am
Also, IF PJ gets around to selling them to me, I'll be upgrading teh seats along with the brake upgrade. I was going to get those mods along with a RUF mod plated with longer shocks front and rear, is it worth it? Cause its my daily, I really want it to be as legal as possible and as its my only car, don't want any hassles with the insurance. Is it something thats possible seeing that i'm not putting uber tires, 1.6 motor and a 5 point coil conversion on the car? Do they mod plate cars for just those few mods? (and running 215s?)
Post Posted: Thu Aug 25, 2011 11:58 pm
I've got vit LWB front, seirra back, standard master cylinder, no adjustable prop valve and the brakes are spot on. Not saying it'll work for everyone but it did for me.
Used local brake shop for lines and T piece. Bent up fencing wire to get exact lengths. Bent the lines at home just by hand, easy to do.
Vehicle: 03 Jimny
Post Posted: Fri Aug 26, 2011 3:29 am
I'm dioing my hardlines now, do you guys just make hardlines that go from the t-piece to the calipers?
I was thinking of just screwing the fitting into the caliper but there is nothing in the to keep the flared tube against the fitting, or does the preassure keep it there?
Post Posted: Fri Aug 26, 2011 3:54 am
you need a flexible hose in there, calipers move as the pad wears!
Vehicle: 03 Jimny
Post Posted: Fri Aug 26, 2011 4:13 am
Thanks royce
Post Posted: Sun Aug 28, 2011 8:23 am
Has anyone done the BenT upgrade with the galant calipers?? Thoughts, comments please people.
Post Posted: Sun Aug 28, 2011 8:32 am
Chop & Christover both have the BenT rear disk/galant caliper combo on their LWB Vitara's?
Post Posted: Sun Aug 28, 2011 8:39 am
I believe it is a slightly different kit. I think the handbrake cable system is a bit different
Post Posted: Tue Aug 30, 2011 8:23 am
Chop or Christover.....how hard was it to find the galant calipers? I have rung a few wreckers up here and they say they weren't that popular and kind of on the old side now :cry:
Post Posted: Wed Oct 12, 2011 10:17 am
Does anyone know what model/year Forester MC to use ?
Users browsing this forum: No registered users and 157 guests
