It is currently Sat Nov 14, 2026 12:42 pm
Post Posted: Mon Aug 29, 2011 8:04 am
hi guys got a lockright that im thinking about installing this weekend. just wondering if i put it in the front does this make it hard to steer when it locks?
yes
Post Posted: Mon Aug 29, 2011 8:06 am
so it would be better not to install it and save for arb?
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Mon Aug 29, 2011 8:12 am
Bingo :helloo:
95 Sierra SJ70 TinTop
Post Posted: Mon Aug 29, 2011 8:13 am
That choice is up to you,
based on needs and finances.
If you can afford arb locker, great,
if not, an auto locker works ok.
Power steering would help with a front locker.
Vehicle: 03 Jimny
Post Posted: Mon Aug 29, 2011 8:15 am
If it's a rear lockwrong then it won't go in the front :helloo:
Lockrights are rubbish in the front.
If you have power steering and drive predominantly dry terrain they are fine.
They are especially annoying on descents.
Post Posted: Mon Aug 29, 2011 10:02 am
But in the rear they're scary and lift wheels :D
Vehicle: 2018 DMAX
Post Posted: Mon Aug 29, 2011 10:05 am
I liked it in the rear more than the front.. Yes they lift wheels but if you drive it right its still effective. And to run a rear lockrite in the front you will need chromos id say.
Post Posted: Mon Aug 29, 2011 10:42 am
really, there are other forums for this type of stuff you know :wink:
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Aug 29, 2011 10:51 am
I had front and rear, but I also had power steering.
It was way better than unlocked, and once I learnt how to control in with my foot (foot off the pedal when you want to turn) it was great, but air locker wins every time, especially on slippary downhill.
I had the Spartan that uses your side gears so there was no issue with running them in the front, it will depends which model of lockright you have.
Vehicle: 2018 DMAX
Post Posted: Mon Aug 29, 2011 11:05 am
:wink: ...... :no:
Post Posted: Mon Aug 29, 2011 11:09 am
It's VERY effective. I couldn't go back to open diffs. Just some brown stain moments from the locker :D
Post Posted: Mon Aug 29, 2011 12:37 pm
misewell just chuk it in the rear n see how it goes.
Post Posted: Mon Sep 05, 2011 1:30 pm
Just to bump this, if you could have one of each air and auto which ends would you choose for both?
Post Posted: Mon Sep 05, 2011 1:31 pm
auto rear, air front.
i drove on a welded rear for a few years and it was fine, but i can't imagine a front diff i couldnt unlock... it'd be terrifying i reckon. lol
Post Posted: Mon Sep 05, 2011 10:53 pm
I'd have auto lockers that could be turned off, both ends, if they existed.
I like the fact an auto can unlock, if for example,
you put one wheel over a big rock, on way down hill.
I often think about auto locking hubs,
converted to a switch in cab, could be good.
Now back to reality.
Only thing I hate is the driveline slack caused by rear auto locker.
Vehicle: 4wd
Post Posted: Mon Sep 05, 2011 10:56 pm
Spool rear
Airlocker front.
Watch out or you'll get sued.
Post Posted: Tue Sep 06, 2011 1:40 am
Why not Air lockers in front and back?
Every problem can be solved with a Ratchet.
Post Posted: Tue Sep 06, 2011 1:44 am
why not just wheel it open diffed!!!
Post Posted: Tue Sep 06, 2011 2:10 am
Money, lockrights are cheap enough that if I don't like it I can get rid of it and still won't break the bank.
tansh wrote:
Why not just wheel it open diffed!!!
Want to get use to driving with lockers before I start comps. There are very few places I have found that I need a locker but I don't want the first time I use it to be in a competitive stage.
Post Posted: Tue Sep 06, 2011 2:17 am
what comps are you talking about entering?
Post Posted: Tue Sep 06, 2011 8:01 am
WTC, it is a local winch truck challenge. I won't be running an auto in it then I just want to know how it feels to run dual locked for a while.
Post Posted: Tue Sep 06, 2011 8:05 am
I'd imagine a bit gay without options. I'm getting air before I do masters as sometimes you don't want a locker while doing some manouvers/sections.
Users browsing this forum: No registered users and 66 guests
