It is currently Wed Jul 29, 2026 3:50 pm
Post Posted: Wed Aug 31, 2011 8:40 am
Hey guys i just bought a 92 mod sierra 1.3ltr and it has a 96 Transfer,
Ive been told that you can not get reduction gears to suit this transfer.
Just wondering if anyone knows if this is true and if not where can i get them.
if you cant get them ill just look out for an original transfer.
cheers.
Post Posted: Wed Aug 31, 2011 8:47 am
If it is a gear drive transfer case there are no problems. 1996 was the change over year. the chain drive coil case isn't a straight swap so you'd have to be keen to screw up the gearing of a WT to bother with a coil case in one.
If the shift pattern is like this:
Then it's a gear drive case, and you are sweet for gears.
The coil shift pattern is straight though (it's not a J shape)
Post Posted: Wed Aug 31, 2011 8:57 am
Awsome thanks heaps for that mine has the J pattern.
The guy i bought it off said it was the 96 chain driven transfer but i guess not.
Vehicle: 4wd
Post Posted: Wed Aug 31, 2011 9:00 am
Did you shift through the case?
Watch out or you'll get sued.
Vehicle: 03 Jimny
Post Posted: Wed Aug 31, 2011 9:02 am
X2 they could of put the original transfercase stick knob back on
Post Posted: Wed Aug 31, 2011 9:03 am
yer its def the j pattern, this is my first zook so i dont know much about em.
Post Posted: Wed Aug 31, 2011 9:09 am
u sure about that shift pattern steve? cbzook is a coiler transfer and it is a J pattern. and im 99% sure mine was to before i got gears.
Post Posted: Wed Aug 31, 2011 9:15 am
my 97 coily has the j pattern it had work done when i bought it, so i don't know if it is original or not.
i hope its a leaffy case ...more info boys !
Post Posted: Wed Aug 31, 2011 9:16 am
I'm 99.99% sure the pattern is different from the Leaf - it doesn't have a neutral or somehting? Hmmm - I used to have a coil case here but I threw it out.
Sorry if I've misled anyone - I was sure there was a difference.
Steve
Post Posted: Wed Aug 31, 2011 9:17 am
yer is there another way to check, without pulling it apart of course
Post Posted: Wed Aug 31, 2011 9:22 am
yep the shape.... hold on give me a few min i have a pic in my photo bucket.......
Post Posted: Wed Aug 31, 2011 9:23 am
Should be able to tell them apart from this:
Coil sierra case, viewed from above:
Leaf sierra case, viewed from above
The coil case is much skinnier through the middle (between the input and outputs) as there's only a chain between them.
Post Posted: Wed Aug 31, 2011 9:24 am
ok that didnt take as long as i thought
left is coiler
right is leafy
Post Posted: Wed Aug 31, 2011 9:27 am
Jonno - the leaf transfer in your pic is a non-4WD light case (early 1.0) It looks quite different to a later case.
Steve
Post Posted: Wed Aug 31, 2011 9:30 am
Steve
your right... however for the purpose of the pic it works..
also notice it was in my coiler for about a year... useing wt shafts and all.
Post Posted: Wed Aug 31, 2011 9:32 am
Someone did some trick work to make the flanges work then :D
Post Posted: Wed Aug 31, 2011 9:35 am
yeah apparently a prev owner of the case was doing a mashinest course at tafe, so he built custom flanges as a project! got top marks 2.. a member on this form still owns the case!
Post Posted: Wed Aug 31, 2011 9:36 am
cheers guys i will have a look tomorrow.
if i could buy you a beer i would!
Post Posted: Wed Aug 31, 2011 9:42 am
hehe flange.
Post Posted: Wed Aug 31, 2011 10:24 am
alien wrote:
hehe flange.
x2 :lol: :lol:
Post Posted: Thu Sep 08, 2011 2:56 am
So have checked and it is the chain drive transfer with the J pattern,
So now wondering if they would of had to change much to do this, im thinking of just buying a Gear drive transfer and changing it back so i can get the reduction gears or does anyone have a better idea.
I really need the reduction gears and im running 31's n the thing goes like a dog.
Cheers guys.
Vehicle: SJ80, SE416
Post Posted: Thu Sep 08, 2011 4:47 am
To clear up, all sierra transfers had a 'J-Pattern' shift.
To interchange the coily and WT transfers, the jackshaft, and the case itself changes.
The mounts transfer are the same. The 4x4 light plug is the same. The coily case is a little slimmer at the top so the jackshaft length changes. The flange holes on the coily case are tapped. The flanges on the WT case have holes for a bolt and nut.
Oh and maybe the shift knob gets a little prettier with the coily case as well LOL.
If you get a WT jackshaft you should be able to change over the case in a couple of hours easily. The gearing will improve also and your speedo should become more accurate - the stock WT case has lower gears as the coily has 3.9 ratio diffs instead of 3.7.
Users browsing this forum: No registered users and 769 guests
