It is currently Mon Sep 21, 2026 5:45 pm
Post Posted: Tue Mar 02, 2010 2:42 am
G'day all
I have a '94 G16B Vitara that stalls after restarting.
Scenario:
- Start the car from cold and go someplace.
- Get someplace and switch off the engine.
- Come back in about 5-10 minutes. Car starts but wont idle and dies.
Work around is to turn on the air con which ups the idle temporarily and eventually after a few minutes all comes good.
The air con trick does not work if the air con was already in use before stopping the engine, have to keep foot on the accelerator instead
The problem eventually clears itself but is a mongrel in traffic...Tried revving the engine to clear it but the only fix is the air con a steady drive or to let it cool
Vapour lock?
Something sticking ?
Something else?
Any clues?
Post Posted: Tue Mar 02, 2010 12:15 pm
Forgot to mention havnig the foot on the brake has an effect as well (lowers the revs) but only after its hot
BCNU Jabba
Post Posted: Tue Mar 02, 2010 3:27 pm
ahhh, check the idle control valve, make sure its not stuck (under the throttlebody). I had the same problem but it seemed to correct itself over time, i did change the intake piping so perhaps there was a leak after the afm?
Post Posted: Tue Mar 02, 2010 3:34 pm
Sounds like it's losing engine vacuum somewhere.. Check all the hoses for splits or cracks....... Check all the inlet manifold bolts are tight.
Do the brakes still work properly? If not, there may be a split in the booster diaphragm.
Post Posted: Tue Mar 02, 2010 4:02 pm
Brakes are fine
When you slow to a set of lights the revs drop to say 300rpm but as soon as you take your foot off the revs come back to normal.
Maybe the vacuum thing is related to the stalling somehow. And it must be temperature driven because I got to work this AM and killed the car then restarted a few minutes later and all was good.
Frustrating
BCNU Jabba
Post Posted: Tue Sep 06, 2011 10:18 am
Did ya get it fixxed jabba? im chasing this problem atm.
Post Posted: Tue Sep 06, 2011 10:46 am
I found the answer on this page http://www.kick-fix.com/EGR.html failure 96-98 I think from memory.
BCNU Jabba
Post Posted: Thu Sep 08, 2011 5:21 am
Cheers jabba, i did that and it worked a treat, had a couple of mill of carbon caked on everywhere.
Users browsing this forum: No registered users and 180 guests
