| Author |
Message |
4x4zook
Joined: Wed Jun 15, 2011 2:25 am Posts: 151 Location: australia port augus
 Posted: Thu Sep 01, 2011 9:18 am |
hi guys just wondering if i can use a 1 ltr transfer case without a switch in my w/t 92 swb sierra untill i can afford reduction gears. is the only different thing between the switched and non switch 1ltr transfers is the switch lol? i dont mind not havning a 4wd light until i buy reductions.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Thu Sep 01, 2011 9:23 am |
No. The driveshaft flanges are different and can't be swapped (They can be swapped on the 4WD light case)
Unless you want to get some machining done or build custom driveshafts, It's not going to be a goer.
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
The flanges are different. You can't put 1.3 flanges on the light less transfer.
4x4zook
 Posted: Thu Sep 01, 2011 9:26 am |
daaaaammmmmmnnnnnnnn. thanx guys
Gwagensteve
 Posted: Thu Sep 01, 2011 9:27 am |
There's a reason they are cheap and available
Steve
PS Actually, the 1.0 non-light case is technically superior to the later case - the intermediate shaft is bearing supported instead of the shaft being static and the gears riding on needle roller bearings.
Anyone whose pulled a light 1.0 or 1.3 case apart knows the intermediate shaft falls apart before anything else because of the needle bearings.
JrZook
 Posted: Thu Sep 01, 2011 10:57 am |
If you have the case also get a set of 1L half yokes then just make up hybrid jack shaft and front driveshaft.
Really not that hard...
_________________ Lil Foot!
Gwagensteve
 Posted: Thu Sep 01, 2011 11:12 am |
If they last.
Not all hybrid unis end up working out.
You can't make 1/2 and 1/2 driveshafts as the driveshaft slip yoke splines are different.
JrZook
 Posted: Thu Sep 01, 2011 1:13 pm |
Gwagensteve wrote: If they last.
What do you mean by that? Back in the day I seemed to have no issues getting it to work. Although it is a bit of stuffing around, the bonus here is that the non-switched cases are pretty much given away these days!
Gwagensteve
 Posted: Thu Sep 01, 2011 8:48 pm |
Because cap height isn't consistent between 1.0 and 1.3 unis, and also I think across uni brands (due to the position of the circlip on 1.0 vs 1.3 unis) I've had some hybrids that were fine, others too tight to assemble and others too loose.
Just an observation.
