It is currently Thu Oct 22, 2026 7:25 pm
Post Posted: Thu Sep 01, 2011 9:18 am
hi guys just wondering if i can use a 1 ltr transfer case without a switch in my w/t 92 swb sierra untill i can afford reduction gears. is the only different thing between the switched and non switch 1ltr transfers is the switch lol? i dont mind not havning a 4wd light until i buy reductions.
Post Posted: Thu Sep 01, 2011 9:23 am
No. The driveshaft flanges are different and can't be swapped (They can be swapped on the 4WD light case)
Unless you want to get some machining done or build custom driveshafts, It's not going to be a goer.
The flanges are different. You can't put 1.3 flanges on the light less transfer.
Post Posted: Thu Sep 01, 2011 9:26 am
daaaaammmmmmnnnnnnnn. thanx guys
Post Posted: Thu Sep 01, 2011 9:27 am
There's a reason they are cheap and available :D
Steve
PS Actually, the 1.0 non-light case is technically superior to the later case - the intermediate shaft is bearing supported instead of the shaft being static and the gears riding on needle roller bearings.
Anyone whose pulled a light 1.0 or 1.3 case apart knows the intermediate shaft falls apart before anything else because of the needle bearings.
Post Posted: Thu Sep 01, 2011 10:57 am
If you have the case also get a set of 1L half yokes then just make up hybrid jack shaft and front driveshaft.
Really not that hard...
Lil Foot!
Post Posted: Thu Sep 01, 2011 11:12 am
If they last.
Not all hybrid unis end up working out.
You can't make 1/2 and 1/2 driveshafts as the driveshaft slip yoke splines are different.
Post Posted: Thu Sep 01, 2011 1:13 pm
If they last.
What do you mean by that? Back in the day I seemed to have no issues getting it to work. Although it is a bit of stuffing around, the bonus here is that the non-switched cases are pretty much given away these days!
Lil Foot!
Post Posted: Thu Sep 01, 2011 8:48 pm
Because cap height isn't consistent between 1.0 and 1.3 unis, and also I think across uni brands (due to the position of the circlip on 1.0 vs 1.3 unis) I've had some hybrids that were fine, others too tight to assemble and others too loose.
Just an observation.
Users browsing this forum: Google [Bot] and 164 guests
