It is currently Tue Sep 22, 2026 3:50 am
Post Posted: Tue Sep 06, 2011 9:15 am
How much lift can you give a Sierra before you have to do something about the steering, and what did you do to rectify the issue
Post Posted: Tue Sep 06, 2011 9:54 am
You can do a high steer kit. Or a drop pitman arm off the steering box. How much lift do you wanna go? Cause ive seen guys do 2inch shackle and 2inch springs and not touch the steering...
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Tue Sep 06, 2011 10:56 am
if you lift the body, you have to put a steering spacer in haha
95 Sierra SJ70 TinTop
Vehicle: Ducati Monster
Post Posted: Tue Sep 06, 2011 11:00 am
i got 2 inch spring, extended shackles, 2 inch body, only done spacer so far but i think i will go for the high steer kit
Post Posted: Tue Sep 06, 2011 11:02 am
I have 2" body and 2" extended shackles, standard steering ATM and had no probs, bout to add 2.5 inch lifted springs. Just never read in build threads what steering set ups people are useing
Post Posted: Thu Sep 08, 2011 5:30 am
i did a 2 inch body lift 2 inch spring and with the steering spacer for the body lift i just put two brand new genuine steering couplings together seemed to do the trick just had to get longer bolts to put it together and a bigger spring for the middle and just doubled up the metal cross plate things u get with them.
Users browsing this forum: No registered users and 200 guests
