Joined: Tue Jun 08, 2010 10:09 am Posts: 782 Location: Wollongong
Posted: Tue Sep 06, 2011 9:54 am
You can do a high steer kit. Or a drop pitman arm off the steering box. How much lift do you wanna go? Cause ive seen guys do 2inch shackle and 2inch springs and not touch the steering...
Joined: Tue Nov 23, 2010 8:01 am Posts: 323 Location: adelaide
Posted: Tue Sep 06, 2011 11:02 am
I have 2" body and 2" extended shackles, standard steering ATM and had no probs, bout to add 2.5 inch lifted springs. Just never read in build threads what steering set ups people are useing
Joined: Thu Dec 16, 2010 5:35 am Posts: 179 Location: sunshine coast
Posted: Thu Sep 08, 2011 5:30 am
i did a 2 inch body lift 2 inch spring and with the steering spacer for the body lift i just put two brand new genuine steering couplings together seemed to do the trick just had to get longer bolts to put it together and a bigger spring for the middle and just doubled up the metal cross plate things u get with them.
Users browsing this forum: Google [Bot] and 198 guests
