| Author |
Message |
CompTruck
Joined: Mon Sep 21, 2009 11:30 pm Posts: 299 Location: brisbane northside
 Posted: Fri Oct 21, 2011 6:06 am |
hi guys. ive got a auto locker in my sierra. believe its a lockright but not sure.
when i go on and off the throttle it bangs as it takes up freeplay i think it is. sometimes when it does it it steers the car one way? is that normal for it?
and also i did a tight turn in a shopping centre carpark today. while the tyre didnt chirp it did make like a clunk clunk clunk clunk noise from the diff and it free wheeled into the parking space. is that normal?
do they need to be serviced or any crap like that? im gunna change the diff oil atleast but. no idea whats in there or how long since its been changed
christover1
Joined: Tue Jul 15, 2008 11:30 pm Posts: 8203 Location: Melbourne
 Posted: Fri Oct 21, 2011 6:13 am |
I get a bit of driveline slack with mine,
more noticeable in an auto,
but otherwise don't know its there.
It may need re shimming.
Or sometimes pins inside break,
you can buy new pins cheap.
ellis
Joined: Wed Sep 08, 2010 8:28 am Posts: 445 Location: GYMPIE QLD
 Posted: Fri Oct 21, 2011 6:35 am |
it sounds fine to me mine did that to
_________________ if u drive a loud toyota ute u drink rum
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Fri Oct 21, 2011 8:38 am |
totally normal
_________________ B4T
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Fri Oct 21, 2011 8:52 am |
Test: Does it make the car really shit to drive on road, go everywhere, and make strange noises?
Result: Working normally.
smiffkid
Joined: Fri Aug 13, 2010 12:55 pm Posts: 3266 Location: perth wa
 Posted: Fri Oct 21, 2011 9:28 am |
need to shim it up a little moe i just pulled mine out for the simple reason that it bangs and smashes all the time have shimmed it up heaps
_________________ dodgy brothers mechanical
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Fri Oct 21, 2011 9:36 am |
smiffkid wrote: need to shim it up a little moe i just pulled mine out for the simple reason that it bangs and smashes all the time have shimmed it up heaps
And a broken pin
_________________ Tell my arse, he actually gives a crap!
smiffkid
 Posted: Fri Oct 21, 2011 10:10 am |
na put new pins in i
CompTruck
 Posted: Fri Oct 21, 2011 10:14 am |
how much the parts cost ya?
CompTruck
 Posted: Fri Oct 21, 2011 1:48 pm |
i did the test on the instructions to check its working properly
you jack it up in gear and when turning the wheels forward you wont be able to coz it will be locked.
and then you hold one wheel and turn the other backwards and you should hear it ratcheting.
then turn tyres forward then turn other wheel backwards
i have 2 proper functioning lockers
abclarke
Joined: Mon Feb 14, 2011 8:19 am Posts: 1966 Location: Couridjah
Vehicle: 1985 Holden Drover
 Posted: Fri Oct 21, 2011 8:20 pm |
Hey Comptruck how annoying is it day to day? Im trying to convince myself to get an auto locker for the rear but i know itll shit me up the wall if its constantly knocking the crap out of itself
_________________ 1989 WT Sierra.
christover1
 Posted: Fri Oct 21, 2011 8:23 pm |
My rear auto is hardly noticeable, mines a daily driver.
It is well bed in, time smooths out the function.
Expect a bit of roughness when first fitted.
Open is best on road naturally,
but not all can afford switchable lockers.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Fri Oct 21, 2011 8:39 pm |
Its not that annoying at all. It's only carparks and stuff that its noticeable.
_________________ mlm
goldpoacher
Joined: Sat Sep 27, 2008 11:30 pm Posts: 85 Location: WA,Vict,NSW Goldfields
Vehicle: MG410 1.6efi broken rear diff
 Posted: Sat Oct 22, 2011 8:51 am |
Make sure equal tyre pressure or the profile is same eg:80% tread l/side with 50% tread r/side will cause load noise under power on hard surface at low speeds.
Most common problem is worn side gears allowing combined excessive backlash (not crown & pinion} between gears.
tomataface
Joined: Thu May 05, 2011 7:50 am Posts: 47 Location: Brisbane
 Posted: Sat Oct 22, 2011 8:40 pm |
I have a swb and it's auto and I never notice it unless going around tight corners where it clicks. My partner has a Hilux with one in the back and it does some strange things especially in carparks. He fixes it by holding the clutch in before you start turning an release it when your straighten up. Doing that helps heaps
_________________ betty...fiesty grandma
