It is currently Sun Aug 02, 2026 12:55 am
Post Posted: Sat Oct 22, 2011 10:00 am
Is there any way to put a hilux gearbox behind a g16b as I would like to do this in a lwb. Sierra
Post Posted: Sat Oct 22, 2011 10:01 am
you'd be suprised how far a grinder and a welder can take you :helloo:
rust is lighter then carbon fiber
Post Posted: Sat Oct 22, 2011 11:08 am
Lowrange sells a adapter to do it. its about 400
Post Posted: Sat Oct 22, 2011 1:46 pm
Why??
Post Posted: Sat Oct 22, 2011 6:12 pm
2stroker wrote:
Why??
Extra weight???? :?
Post Posted: Sat Oct 22, 2011 6:20 pm
steak_knife wrote:
2stroker wrote:
Why??
Extra weight???? :?
Wouldn't a GQ box be a better option then? Stronger too to handle the power of the mighty G16B! 8O
Post Posted: Sat Oct 22, 2011 6:27 pm
Another option is G16b-Vitara gbox-adaptor-lux transfer
SierraDan wrote:
steak_knife wrote:
2stroker wrote:
Why??
Extra weight???? :?
Road-ranger..... :helloo:
Post Posted: Sat Oct 22, 2011 6:31 pm
steak_knife wrote:
SierraDan wrote:
steak_knife wrote:
2stroker wrote:
Why??
Extra weight???? :?
It'd be like a twin transfer haha
Post Posted: Sat Oct 22, 2011 6:32 pm
SierraDan wrote:
steak_knife wrote:
SierraDan wrote:
steak_knife wrote:
2stroker wrote:
Why??
Extra weight???? :?
Won't need diff gear's either, cause they will be on the ground... :lol:
Post Posted: Sat Oct 22, 2011 6:56 pm
Lucky it's a LWB, might even be able to use SWB rear shaft! :crazy:
Post Posted: Sat Oct 22, 2011 8:24 pm
BlueS
Where do you get them from?
Post Posted: Sat Oct 22, 2011 9:35 pm
Brett wrote:
BlueS
low range maybe?
Post Posted: Sat Oct 22, 2011 10:02 pm
i want to run a hilux transfer because i am putting hilux diff under it and the transfer would line up with the rear diff and has a better low range than a vit transfer and if i run a gear driven hilux transfer i can gear it down more with a kit for marks adapters. there is not that much difference in size i don't think and i am not to fussed about weight or i would have just used WT diffs that i have
Post Posted: Sat Oct 22, 2011 10:08 pm
The Hilux box is a fair bit longer than the Vit box
Are the Hilux transfer gear or chain driven?
Post Posted: Sat Oct 22, 2011 10:16 pm
older model are gear and new ones are chain
Post Posted: Sat Oct 22, 2011 11:36 pm
You will have to run 4.88-5.12 in the diffs to get the high range okish. What size tyres?
I liked the thought of where your going with this as i was looking into similar, But i didnt like the weight and the actual size of the box's.
Post Posted: Sun Oct 23, 2011 12:21 am
My new build utilises a G16B bolted to a Vitara bellhousing, bolted to an SOS RingR adaptor, bolted to Hilux W56 gearbox, bolted to twin hilux transfers, one of which has reduction gears fitted.
RingR is available from Lowrange.
Post Posted: Sun Oct 23, 2011 1:06 am
I will only be running 33-35 tyres. i want to set it up with coil overs and hydro bump stops. so i want to do more hi speed stuff than crawling.
Post Posted: Sun Oct 23, 2011 1:42 am
If you are going down that path you might as well bolt in something with enough power to turn that combination otherwise crawling will be your only option. There are bellhousings available for "W" series box to "A" series and "S" series Toyota engines.
Post Posted: Sun Oct 23, 2011 1:53 am
Looks like you will be cutting that rear crossmember out :lol:
Post Posted: Sun Oct 23, 2011 1:58 am
Yep... :twisted: It goes this friday.
Post Posted: Sun Oct 23, 2011 8:43 am
I was thinking "why?" :lol:
then i looked closer... :lol: :lol: :lol: :lol:
Users browsing this forum: No registered users and 1206 guests
