It is currently Fri Oct 09, 2026 1:45 pm
Post Posted: Sun Nov 13, 2011 1:18 am
hey guys im having some serious trouble removing my rear axles i have tried pulling with the wheel on i have tried the chain and hammer method still no luck any other ideas
Vehicle: 03 Jimny
Post Posted: Sun Nov 13, 2011 1:22 am
I had the same problem. I just chain down the other side of the car to a concrete post and got a bigger hammer :D
Post Posted: Sun Nov 13, 2011 1:26 am
i dont have a bigger hammer but i guess i will keep trying until i get a good way of doing it
Vehicle: Serria
Post Posted: Sun Nov 13, 2011 2:53 am
What you need is a slide hammer.
Sj80 cab on sj70 chassis 5inch lift 1.6 turbo inte
Post Posted: Sun Nov 13, 2011 2:59 am
put your rim on, and beat your rim with a rubber mallet. weaves taught me that :D
Post Posted: Sun Nov 13, 2011 6:37 am
Unbolt the backing plate?
Mine slide out with a good pull on it.
Vehicle: LWB Sierra & XL7
Post Posted: Sun Nov 13, 2011 6:57 am
X 2
4lb hammer / mini sledgie FTW
I beat the tyre instead to prevent damage to the rim.
Post Posted: Sun Nov 13, 2011 7:06 am
Get a 6ft length of chain and bolt it to the hub studs. Then using a sledge hammer or a crow bar swing it into the looped end of the chain. Same effect as a slide hammer.
Post Posted: Sun Nov 13, 2011 8:22 am
i have already tried using beating it by the tire and still no luck im gonna to try a axle puller tomorrow hopefully it will work. and yes the backing plate is undone
Vehicle: Jimny
Post Posted: Sun Nov 13, 2011 8:27 am
put a wedge inbetween the backing plate and the axel
DONT BUY A GQ! zooks are better. i have both :)
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sun Nov 13, 2011 6:49 pm
Have you taken out the other side and unbolted the third member?
On my 1l the housing was jammed against the axel so badly, I put the hand winch on it, really tight and hit housing where the axel would have been against it with the back of an axe and it came out. If that had failed I would have cut the tube off near the bearing end, I was changing the housing anyway..
Vehicle: '94 suzuki maruti
Post Posted: Sun Nov 13, 2011 7:59 pm
i undid the wheel nuts and left them on just a couple of threads and used the tyre as a slide hammer. worked perfect after a couple of hits :D
Post Posted: Mon Nov 14, 2011 4:57 am
I ended up getting a slide hammer and after 5 or 6 goes they both came straight out. and thanks for all the ideas guys
Users browsing this forum: Google [Bot] and 165 guests
