It is currently Thu Oct 08, 2026 7:21 am
Post Posted: Fri Aug 22, 2008 1:11 am
as the title says, what would cause the handbrake light to come on while still depessed :?: any ideas :!:
cheers andrewa.
Post Posted: Fri Aug 22, 2008 1:14 am
low brake fluid, same light arent they?
Post Posted: Fri Aug 22, 2008 2:16 am
i'll check the fluid level tomorrow & see if that makes a difference.
Post Posted: Fri Aug 22, 2008 2:18 am
My friend had the same thing happen too, everytime we go around the corner the light would come one. Turned out to be low brake fluid :)
Post Posted: Fri Aug 22, 2008 11:05 am
Either that or the switch on the handbrake lever is playing up
Post Posted: Fri Aug 22, 2008 11:24 am
I had the same problem a few years back with my GV. Turned outto be a faulty handbrake switch. 8)
Post Posted: Fri Aug 22, 2008 10:36 pm
check ur brake fluid
Post Posted: Sat Aug 23, 2008 1:03 am
brake fluid was a bit low, topped it up & seems to be ok. :)
Post Posted: Sat Aug 23, 2008 1:07 pm
if your brake fluid was that low it might be a idea to check your brake pads, the fluid doesn't go anywhere unless you have a leak and slowly goes down as your pads wear.
Post Posted: Sat Aug 23, 2008 5:56 pm
My top up is usually once a week, My rear drums leak..
Just gotta get the time to put my new pistons in :P
Users browsing this forum: No registered users and 159 guests
