| Author |
Message |
andrewa
Joined: Fri Aug 25, 2006 11:30 pm Posts: 278 Location: bundamba
 Posted: Fri Aug 22, 2008 1:11 am |
as the title says, what would cause the handbrake light to come on while still depessed  any ideas
cheers andrewa.
royce
 Posted: Fri Aug 22, 2008 1:14 am |
low brake fluid, same light arent they?
andrewa
 Posted: Fri Aug 22, 2008 2:16 am |
i'll check the fluid level tomorrow & see if that makes a difference.
mrpham
Joined: Thu Aug 07, 2008 11:30 pm Posts: 8 Location: Brisbane
 Posted: Fri Aug 22, 2008 2:18 am |
My friend had the same thing happen too, everytime we go around the corner the light would come one. Turned out to be low brake fluid
Rockhopper
Joined: Sun Jun 22, 2008 11:30 pm Posts: 1265 Location: Chipping Norton
 Posted: Fri Aug 22, 2008 11:05 am |
royce wrote: low brake fluid, same light arent they?
Either that or the switch on the handbrake lever is playing up
zook37
Joined: Thu Dec 28, 2006 10:30 pm Posts: 124 Location: Bundaberg
 Posted: Fri Aug 22, 2008 11:24 am |
I had the same problem a few years back with my GV. Turned outto be a faulty handbrake switch.
bill929
Joined: Tue Aug 05, 2008 11:30 pm Posts: 5 Location: brisbane
 Posted: Fri Aug 22, 2008 10:36 pm |
andrewa
 Posted: Sat Aug 23, 2008 1:03 am |
brake fluid was a bit low, topped it up & seems to be ok.
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Sat Aug 23, 2008 1:07 pm |
if your brake fluid was that low it might be a idea to check your brake pads, the fluid doesn't go anywhere unless you have a leak and slowly goes down as your pads wear.
BlueSuzy
 Posted: Sat Aug 23, 2008 5:56 pm |
My top up is usually once a week, My rear drums leak..
Just gotta get the time to put my new pistons in
