It is currently Fri Oct 09, 2026 11:48 am
Vehicle: Jimny, Lifted on 30's
Post Posted: Sun Nov 27, 2011 7:36 am
Well as some of you might know i have a custom rear bar, if i increase the size of the spare tyre on the back it rubs on the bar.
I have heard of people chopping and re welding or spacing the tyre carrier upwards and outwards to allow for the larger spare.
I am needing a 235/75 spare on a 15x7 rim.
Have any of you guys got a photo of how you modified yours?
And also any trouble you had?
Thanks alot, Nick.
:helloo:
Jimny, 3" Lift, 30" Treps, Gears
Post Posted: Sun Nov 27, 2011 7:38 am
No need to modify it for a 235...just get a off-set rim or wheel spacer...
Post Posted: Sun Nov 27, 2011 7:43 am
because were the groove is in the origional rear bumper is gone and its now a solid bar accross there so it will need to stick out a bit, were can you get wheel spacers from?
heres a pic with a 215, had to space the bottom out alot with washers, so it would clear.
Post Posted: Sun Nov 27, 2011 7:44 am
PM Dank :wink:
Post Posted: Sun Nov 27, 2011 7:45 am
maybe a combo of the offset rim and wheel spacers will clear it.. !
Cool thanks for the ideas! I shall try it out.
Post Posted: Sun Nov 27, 2011 7:52 am
Read through zukenutters black jimny... pretty sure he made one.
Post Posted: Mon Nov 28, 2011 4:59 am
sweet thanks drew, i think il just space it seems like the easiest option!
Users browsing this forum: No registered users and 174 guests
