It is currently Thu Aug 06, 2026 12:43 am
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2  Next
Post Posted: Wed Nov 30, 2011 8:31 am
ok so I haven't yet dedicated a thread to my problem until now. I am at my witts end.
This problem is doing my head in and I need to sort it out asap.
My g16B vitara is having an intermittent idle problem.
It randomly decides to idle very low. Happens quite alot sometimes and then hardly ever other times.
I.E it will drop down to stalling point and the check engine light come up on the dash due to low idle.
I pull codes and I get nothing.
Now what i've done to fault find
1) cleaned IAC valve 3 times
2) cleaned AFM 3 times
3) spark plugs changed
4) filters changed
5) reset computer
6) checked fuel pressure
When I first start the car cold it runs fine. Starts to warm up and it starts randomly faulting.
When I say randomly I mean, I can drive for 2 hours straight (start stop) fine....all of a sudden I will stop and the idles drop. next set of lights it will idle fine.
The idles vary. Sometimes it will idle about 700rpm and others 200<RPM.
If I remove the leads whilst running the motor does what it should and runs like crap.
Now before you say take it to a mechanic and get a pro to do it. I left it at a shop and the car made a liar out of me :oops: ran perfect.
Then I was informed its $90 p/h to fault find...the fact that its very random could see me spending a lot of money on it.
So can anyone make any suggestions?
Post Posted: Wed Nov 30, 2011 8:33 am
Carby needs a rebuild :crazy: :lol:
Post Posted: Wed Nov 30, 2011 8:40 am
lol this could be my problem........Should I get rid of the EFI and put on a webber for the extra horses?
Post Posted: Wed Nov 30, 2011 8:41 am
:rofl: :rofl: :rofl: Now your on the right track :wink:
Post Posted: Wed Nov 30, 2011 8:57 am
not sure man, but mine did a similar thing but it has grown out of it. but still idles low like you say randomly.
Post Posted: Wed Nov 30, 2011 8:59 am
its very frustrating. sometimes mine stalls. I was at the lights the other day and when I went to take off it stalled haha
Post Posted: Wed Nov 30, 2011 9:03 am
checked for vacuum/air leaks?
Post Posted: Wed Nov 30, 2011 9:13 am
I sprayed wd-40 on all the vaccum hoses whilst the car was running. Made no change. All hoses seem in good condition and not perished.
I know the exhaust is buggered. Possibly cat OS blocked and causing it?
Post Posted: Wed Nov 30, 2011 8:57 pm
get your exhaust fixed put in new vac hoses so u know they are fine and clean out the air filter and give the afm a good clean out with the proper air flow meter cleaner if thats still causing you trouble ide be looking at fuel filters or even injectors maybe?
Vehicle: 1993 Sierra 1.6 efi Vit motor,
Post Posted: Wed Nov 30, 2011 9:16 pm
I had a similar problem, check the throttle body water jacket.
Adventure before Dementia
Post Posted: Wed Nov 30, 2011 10:58 pm
How much coolant in the rad?
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Nov 30, 2011 11:04 pm
mines started doing this since my exhaust got a leak in it (only small, but its there) - im assuming that the small hole is sending the wrong info back to the computer. Its not really bothering me though as it only seems to do it when the engine is on the cold side (5-15mins after startup) - after its warmed up theres no problem.
Post Posted: Thu Dec 01, 2011 4:06 am
All brand new filters and made no change. This includes air and fuel.
Cleaned the afm numerous times with contact cleaner. Good stuff.
Plenty of coolant. I just changed it.
Throttle body water jacket?
Post Posted: Thu Dec 01, 2011 5:35 am
Coolant runs through the throttle body which can become blocked. This will cause erratic idling.
Post Posted: Sat Dec 31, 2011 11:29 pm
What are the chances its the spark plug leads?????
Post Posted: Sat Dec 31, 2011 11:45 pm
Should do it all the time.......
Egr????
Post Posted: Sat Dec 31, 2011 11:47 pm
Spark plug leads don't fail intermittently.
You need to spray all the vacuum hoses with an ether product, something like 'Ezy Start' or 'Start Ya Bastard'. This will make the revs pick up if there is a leak.
Have you cleaned all around the throttle butterfly and into the intake manifold as well? Does the throttle butterfly close properly?
Could a cracked exhaust manifold cause this?
Haven't checked as I have the heat plate on still. But could this be playing with the 02 sensor?
How do I check the egr?
Cheers Steve
Post Posted: Sat Dec 31, 2011 11:52 pm
Cheers Steve
Pull it apart & clean it, I've seen Jim's & swift's have intermittent idle problem's from EGR....
Post Posted: Sat Dec 31, 2011 11:53 pm
I have cleaned intake hose thingo. Cleaned the butterfly all seemed normal however, I only have a rough idea of what normal look like. Seems to close flush.
I sprayed the hoses today with carb cleaner but it was hard to tell if the revs changed. Will starting fluid make a very noticeable change in revs?
Post Posted: Sat Dec 31, 2011 11:57 pm
Carb cleaner, wd40 and whatever else doesn't work. You need the ether as it's highly combustible. It is a spray just as the others and the revs will pick up by 2-500rpm depending on the leak. Yes, it is very noticable
Post Posted: Sun Jan 01, 2012 12:23 am
Just tried start ya bastard and didn't change. This is doing my head.in lol
Post Posted: Sun Jan 01, 2012 12:25 am
Did you wiggle hoses while spraying? Have you looked into the EGR yet?
Post Posted: Sun Jan 01, 2012 12:34 am
Where about is the egr sorry?
It really is intermittent. Went for a drive then and it was perfect. Maybe its temperature related?
Post Posted: Sun Jan 01, 2012 12:58 am
Ok. so this is clearly a common problem, mine also does this. Not all the time, and its not temperature dependant, mine does it sometimes when its stone cold, and other time after its been driven for hours and hours...
My next thing on the To do list is Change the O2 Sensor.
Tried
-Plugs (checked gapping)
-Leads
-Dizzy Cap
-Changing all the Filters.
-Servicing using different oil.
-Temperature Sensors
-Oil Pressure Sensor
-checked for vacum leaks etc....
Stocker
Post Posted: Sun Jan 01, 2012 1:10 am
I'll go get a pick if I remember......
Post Posted: Sun Jan 01, 2012 1:32 am
Tried
-Leads
-Dizzy Cap
im sure once a soloution is found many people will be very happy :D
i can barely go offroad as my car runs like crap so crawling is a struggle :(
Post Posted: Sun Jan 01, 2012 1:34 am
Can you see it in these pics Steve?
Sorry about the mess :D
Post Posted: Sun Jan 01, 2012 2:18 am
Is anyone else noticing shit fuel economy?
Post Posted: Sun Jan 01, 2012 2:38 am
8O looked at your crank pulley??? 8O
Users browsing this forum: Google [Bot] and 514 guests
