It is currently Wed Nov 04, 2026 3:31 pm
Post Posted: Sat Dec 03, 2011 7:54 am
hey all, just wondering what size battery everyone is running for their second battery in a dual battery system in a 1992 sierra, i want to run a slightly bigger battery than the stamdard battery, but am a little unsure of the size constraints, thanks matt
Post Posted: Sat Dec 03, 2011 8:07 am
Double 'A' in mine pompoms
Post Posted: Sat Dec 03, 2011 8:25 am
He wants to know what size for his Sierra not his vibrator :finger: :finger: :finger:
Depends on where you put it I guess. Is the current one the standard size small Sierra one? Are you upgrading that as well? What about alternator upgrade??
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Sat Dec 03, 2011 8:26 am
I use a Redarc soleniod and a 750CCA Supercharge (Primary is a 650CCA Supercharge though)
If at first you don't succeed, get a bigger hammer
Post Posted: Sat Dec 03, 2011 8:53 am
Doesn't every body use a deep cycle battery for running cool stuff? Like camp lights, engel and the like?
Post Posted: Sat Dec 03, 2011 9:02 am
Some of those supercharge batteries have a very good amp hour life :wink: We use them in our trucks at work, unfortunately they go flat from time to time because silly people leave the flashing lights on, our auto sparkie is very good and usually replaces all 4 batteries, even though they are only 6 months old. Bit of a recharge and they are like brand new 8) 8)
Vehicle: nt sierra
Post Posted: Sat Dec 03, 2011 9:32 am
optima D34 yellow top.
Dank on here sells them for the cheapest ive found. second to that is JB hifi - go to a branch that does car audio.
Post Posted: Sat Dec 03, 2011 9:42 am
Batteriesdirect.com.au beat dank price by a decent amount in August. They always have sales on the optimas. Even free delivery.
Post Posted: Sat Dec 03, 2011 9:43 am
haha good on you fellas :finger: :finger: i have an upgraded altenator, and a redarc solenoid coming at the moment and want to upgrade both batteries, i was looking for the maximum dimensions of the batteries i can use, length width and height as my workshop sells a huge selection of deep cycle batteries for all earthmoving gear so the only thing i have to go off is dimension and post location
Post Posted: Sat Dec 03, 2011 9:56 am
An N70 is a little too big to fit on the passenger side but might fit the drivers side with some mods
N50 is about as big as they go, most trays seem to accommodate the normal 8" Commodore size battery
but why dont you exercise some free thinking and get a tape measure and see what battery will fit
Post Posted: Sat Dec 03, 2011 10:03 am
thanks royce, i was intending on doing that anyway, but a little bit of a baseline is good to determine where i can start from
Vehicle: 2018 DMAX
Have an N70 in in the stock spot, just needed the end of the try removed and a new clamp made... Good for running lots of stuff with a small alt..
Post Posted: Sat Dec 03, 2011 10:43 am
We've discussed this once or twice before....... thought I'd be a smart arse so the OP can learn to search :thefinger:
Post Posted: Sat Dec 03, 2011 6:55 pm
You smart people shit me to tear's..... :cry:
Post Posted: Sat Dec 03, 2011 10:26 pm
x2 :oops:
Vehicle: Coil Sierra
Post Posted: Sun Dec 04, 2011 10:10 am
I moved my fuse box on the drivers side a few inches forward and fitted a 57 high performance centuary. Have a n70 to go in next for winching, pass side i moved charcoal canister to left. Weight is the problem, n70 must be altleast 4 times as heavy as a standard size.
Post Posted: Mon Dec 05, 2011 7:49 am
Have an N70 in in the stock spot, just needed the end of the try removed and a new clamp made... Good for running lots of stuff with a small alt..[/quote]
Is that even possible??? 8O I thought the battery was just a storage for electricity?? :? And with a winch or spotlights the Alt would burn out even with a bigger battery??
Post Posted: Mon Dec 05, 2011 5:53 pm
2 x N50's in mine with a simple continious duty solenoid setup to link/seperate them.
Vehicle: SJ70 1993
Post Posted: Tue Dec 06, 2011 12:12 am
I got an N70 in my dual set up. Ill see if i got a pic
Lock, Drop and roll
Vehicle: 2018 DMAX
Post Posted: Tue Dec 06, 2011 12:19 am
Maybe one of the smart people can word this better.... A bigger battery can take a larger load for a longer time than a smaller battery, yes it will eventually run out of juice but not for a longer time than a small stock battery...
Post Posted: Tue Dec 06, 2011 7:06 am
Yeah I get that bit.... but how does your alternator cope with the charging?? does it smoke? :?
Vehicle: 2018 DMAX
Post Posted: Tue Dec 06, 2011 7:20 am
Works fine... Shouldn't be an issue until the battery is so flat your relying on the alternator alone.. And I wouldn't want to spend that long in it :? If I was winching I would look at a alt upgrade. I drive often enough with out everything turned on anyway, battery stays nice and charged..
Post Posted: Tue Dec 06, 2011 7:37 am
Cheers for that mate :D
Users browsing this forum: Google [Bot] and 87 guests
