It is currently Mon Nov 02, 2026 4:09 pm
Post Posted: Tue Dec 06, 2011 6:47 am
Hey guys, just hit 1000 K's roughly on my rebuilt G16B vit engine... So time to dump the running in oil and put new stuff in...
What oil do I want to run?
I am hoping I dont get 5 different answers lol..
Thanks guys
Shane...
Post Posted: Tue Dec 06, 2011 6:51 am
Find the best 10w40 or 15w40 you can, then get the next level up
Post Posted: Tue Dec 06, 2011 6:53 am
What do you mean get the next level up?
Post Posted: Tue Dec 06, 2011 6:56 am
get better, there is no such thing as too high a quality oil
I use motul turbolite 4100, my engine has 305000km and blows no smoke and uses no oil, cheap insurance I reckon
Post Posted: Tue Dec 06, 2011 7:44 am
i have been using diesel oil in all my cars for the last 10 years, few rebuilds, na stroker and boost on na engines, high k engines with low comp and new cars. never had a problem, last engine i tore down after a rebuild (kissed a piston, broke a valve) the bearings looked like new.
diesel oil is designed to work under higher loads, temps and with a dirty fuel.
Vehicle: SJ51T
Post Posted: Tue Dec 06, 2011 8:17 am
when me and a mate built his WRX motor with forged pistons, we were told to run only mineral oil for the first 20k. does this apply to most other engines or was it only because of the forged pistons?
Post Posted: Tue Dec 06, 2011 8:49 am
i run 20w50 in mine... no syth or semi synth.
this is from the SJ413 FSM:
Post Posted: Tue Dec 06, 2011 9:02 am
that is said to all sj413s all over the world, not specific. but yes use the best.
royce, how much do you pay for motul?
Post Posted: Tue Dec 06, 2011 9:11 am
i checked and the the vitara manuals say the same... its pretty dam specific giving the temperature ranges and what oil to run =) lol
given perth's average temp is 18.6*C (average min of 12.7 and max 24.5), peak maximums of 44*C and peak lows of 0*C i'd say 20w50 is spot on.
Vehicle: Sj70 tintop
Post Posted: Tue Dec 06, 2011 9:15 am
i run 10w 60 penrite fully synthetic, both zooks like it thus far.
Sj70 tintop
Post Posted: Tue Dec 06, 2011 9:37 am
is there any truth at all that, by changing the type (eg mineral oil to semi or fully synthetic) can damage/ruin the seals? and isnt good for the engine in general. once running a certain type, it should be stuck with?
Post Posted: Tue Dec 06, 2011 6:14 pm
when we do recond engines at work the engineers that rebuild them have always said to run a mineral oil in them for at least the first 10000klm. something to do with some of the additives in the synthetic oils can cause glazing of the bores (I'm just a mechanic though, not a scientist, so i just do as I'm told)
Post Posted: Tue Dec 06, 2011 6:46 pm
I'mwith am above poster I run diesel 15 40 in mine but if you want better than that go straight to a good synthetic oil and stick with it
Post Posted: Tue Dec 06, 2011 7:50 pm
5l is $60 or so
Post Posted: Tue Dec 06, 2011 7:51 pm
no, the seals usually only last 150k anyway
Post Posted: Tue Dec 06, 2011 10:27 pm
Thanks guys
Post Posted: Tue Dec 06, 2011 10:30 pm
what about fully synthetic diesel oil?
recommended?
Sj70 tintop
Users browsing this forum: No registered users and 532 guests
