It is currently Thu Oct 15, 2026 5:55 pm
Post Posted: Sat Jan 28, 2012 3:58 pm
hey guys, i have a 92 soft top sierra and i have a lot of play in my steering i was just wondering if any off you guys know how to fix this?
thanks,
Haurp00ned
Post Posted: Sat Jan 28, 2012 6:10 pm
Check:
Tierod ends- no play in them, helps with 2 people, 1 to steer back and forth, 1 to check
uni joint in steering shaft-no play in it.
rag joint-not ripped
If all else is good, try adjusting the screw in the top of the steering box. Little bit at a time,Dont screw it in too much, Where your steering is centered, thats where all the wear will be. So if you adjust when the steering is nice and tight when wheels are straight, you might not be able to turn!
Post Posted: Sun Jan 29, 2012 7:39 pm
All of above
and check the uni jiont in the steering shaft near firewall
Post Posted: Sun Jan 29, 2012 8:59 pm
TasRat wrote:
All of above
i said that. :lol:
Also make sure the outer splines arnt slipping on the shafts. had this before! Scarry!
Users browsing this forum: Pezooki and 336 guests
