It is currently Sun Nov 01, 2026 1:55 am
Vehicle: LWB Sierra & XL7
Post Posted: Thu Dec 15, 2011 8:26 am
For the past hour or so I have been trying to cross referance the diameter of the Rear Lower Control arm bush through super pro's online catologue but I'm not having too much luck.
I'm probably doing something wrong but I can't find it.
The part number on the Calmini bush is 2661
OD = 38mm
ID = 20mm
Wall thickness = 8mm
Overall length = 33mm
BTW. Pedders are a bunch of turds !!
Make me leave it there only for them to advise me that they're about $120 for both sides, when I thought I'd just bight the bullet they get the wrong ones in. I was hoping to have it in by now.
Post Posted: Thu Dec 15, 2011 8:34 am
this thread makes mention of gemini rear trailing arm bushes being the right ones for the front control arms & i'm pretty sure calmini use the same bushes for the rear. http://auszookers.com/index.php?name=Fo ... ush#478190
http://www.whiteline.com.au/Plus/produc ... ber=W61490
i have a diff drop bracket bush at home, i can measure to see what size it is?
Post Posted: Thu Dec 15, 2011 9:02 am
W61490 KIT SPECIFICATIONS
OD = 34.8
ID = 16 mm
Length = 31.8
VEHICLE APPLICATIONS
Holden (GM) GEMINI TX, TC, TD, TE, TF, TG (1975-85)
Post Posted: Thu Dec 15, 2011 9:06 am
you could get some custom ones made up... might be an idea to get some Rubber ones made up?
Stocker
Post Posted: Thu Dec 15, 2011 9:08 am
I think I have a BINGO... can someone confirm please.
W73078
OD=38
ID= 19
Length = 33.5
Tube size = 19X14.3X70
'92 Vitara & Camper trailer
Post Posted: Thu Dec 15, 2011 9:16 am
This might look a bit confusing but this is the search on the all teh bush's with roughly a 38mm diameter.
Type Part # * # Qty OD(A) ID(B) Length Flange thickness Flange OD Base width T/Tube
1 W52152 4 37.1 19 25.7
1 W52217 4 37.1 19 25.7 19x12.2x50
1 W61607 4 37.2 24.1 33.1
1 W62914 4 37.3 22.2 19.6 22.2x17x40
1 W71657 4 37.7 19 45.5 19x14.3x91
1 W81133 4 37.7 25.5 29.3
1 W51307 4 38 19 28.5 19x12.6x60
1 W72317 4 38 19 36.5 19x15x39
1 W73078 4 38 19 33.5 19X14.3X70
1 W81429 4 38 24.3 34.4
1 W51262 4 38.1 19 28.5 19x12.6x57
1 W71562 4 38.2 25 41.5 25x19.2x84
1 W51769 4 38.6 19 29 19x12.2x56.5
1 W61222 8 38.7 19 24.7 19x12.2x50
1 W52973 4 38.9 25.4 29.5 25.4x20.2x60
Post Posted: Thu Dec 15, 2011 9:57 am
can you back search to see what it's used on?
Post Posted: Thu Dec 15, 2011 10:15 am
http://www.whiteline.com.au/product_det ... _vehicle=1
$109 per kit of 4.. ouch
Aftermarket 63mm Spring eye front
Having a look at W72317 Same OD and ID different length, I could cut it down, $61.20
Front leaf spring eye
Post Posted: Thu Dec 15, 2011 10:20 am
you can buy a whole kit from low range for about 1/2 that http://www.lowrangeoffroad.com/index.ph ... ystem.html
Post Posted: Thu Dec 15, 2011 10:26 am
check toyota 4wd shackle bushes? would have to be close
old holden (like HR) might be similar too
have you asked Calmini if they are off something else? I am sure if you were to tell em you need them faster than the time it would take to post them here and said you would complain about it on the internet they might be able to help you out :D
Post Posted: Thu Dec 15, 2011 10:36 am
Yeah I know, but I guess I'll have to pay more for being in a rush :(
I'm expecting the heim joint to arrive any day now. I should've just gotten the replacement kit at the same time but thought buying locally would be cheaper and quicker. And for the calmini bush's to stuff up so quickly at least I'd have a part number that I can go into a shop and say yep I want these ones.
I'm getting Jody to cross referance the dimention's with the catologue's at her work, hopefully she can order them in for me and get a nifty discount. ;)
Post Posted: Thu Dec 15, 2011 5:32 pm
how come low range have the bush kit cheaper than calmini
Post Posted: Thu Dec 15, 2011 9:45 pm
Jody just got back to me after calling Super pro and they have confirmed that the calmini rear control arm bush's are the same dimentions as Vitara front standard control arm bush's.
And cost about $60 for both sides.
Post Posted: Mon Dec 19, 2011 7:37 am
Onkie Donkey
Teh part number my girlfriend ordered in from superpro / fulcrum is SPF 0920K
Suprisingly enough they are to suit Lower Rear control arm for the Vitara, In the catalogue it lists it for the rear but on the packet they say Front lower inner bush, and here we all are thinking the calmini bush's are different to standard.
Well yes and no. They are a 98% perfect fit.
The only difference to the Calmini bush's is that the lip / flange is about 1mm thicker and the body of the bush is about 2mm shorter. Being shorter doesn't really matter but the difference in the lip will mean that there is a 2mm or so gap in the crush tube to the end of the bush, which isn't too much of a big deal. I will either grind down that 1mm or put a washer in the end of the bush. The diameter of the bush is a perfect fit into the tube of the Calmini control arm, I think the calmini bush may be about 0.5mm larger which needs for it to be pressed in. but with the superpro bush I had to tap the crush tube in slightly with a hammer for it to sit in there properly.
So for a quick fix that you can order from any semi decent car store, yes great success. But if you plan on changing them it may be cheaper to get them sent from lowrange.
Post Posted: Thu Mar 08, 2012 8:22 pm
how are the super pro bushes holding up Mr Box?
mine have done nearly 100,000kms & the diff end of the lower trailing arms are quite chewed out as i discovered today
Post Posted: Thu Mar 08, 2012 9:38 pm
Interesting - I ordered the complete kit direct from Calamari, was listed at $59, so yeah, more than LROR.
Think it only took a week or so to get to me, which was a pleasant surprise.
I'm in the process of getting them in now... FWIW they are not all identical, there is more of a taper on some, and two sets are close enough that one sits in the rear arms quite nicely, but the actual ones just need a little pressuasion to sit in.
I'm just working them out a set at a time.
Post Posted: Fri Mar 09, 2012 7:45 am
Have you got a link to their listing DarkHorse"?
I had a look at both LROR and Calmini but can't see a specific bush kit.
* hold that thought - found it :oops:
Post Posted: Fri Mar 09, 2012 10:52 am
FWIW the price difference between LROR and Calmini is offset by the postage cost.
They both add up to just over the US$100 mark with the postage included.
Post Posted: Fri Mar 09, 2012 8:59 pm
I havn't even had a chance to install them, been busy with other stuff on the weekends, I still have the "get out of shit for now" standard arms in there. I just want to get the rolla rego'd in case something unexpected happens with the Vit that I won't be able to drive it. So probably in a week or two.
Post Posted: Tue Mar 20, 2012 1:40 pm
I'd just like to put a plug in for LowRange Offroad.
They had the bushes to me way quicker than the local suppliers managed earlier this year.
I'm impressed and won't hesitate to order from them again.
Post Posted: Tue Mar 20, 2012 3:39 pm
I've just ordered a bush kit from them on Friday, hope you didn't get the last one they had in stock. As I haven't heard that it's been shipped yet. 8O
Post Posted: Tue Mar 20, 2012 7:16 pm
I really only needed the rear control arm bushes atm but got the whole kit anyway. I've put them in today so have the rest of the kit sitting there. If you get really stuck let me know as there are heaps of bushes there.
I looked and counted, and figured there are heaps more than I need. I only have the best bits of the Calmini kit on so figure some must be spare (for the rear A-frame for instance).
If you are waiting too long I could forward some on too you to get you started.
Post Posted: Tue Mar 20, 2012 7:23 pm
hahha, it's the rear trailing arm bushes that i'm chasing... cheers for the offer, i'll let you know how i get on.
Post Posted: Tue Mar 20, 2012 8:30 pm
bummer, I got one side worth (4)
Post Posted: Thu Mar 22, 2012 9:50 am
they got sent overnight, so should see them in a week & I got an $11 refund on shipping. Lowrangeoffroad.com Armsup
thanks again for the offer DSzuke. 8)
Users browsing this forum: Google [Bot] and 492 guests
