It is currently Wed Nov 04, 2026 3:04 pm
Post Posted: Fri Dec 16, 2011 11:44 pm
im rebuilding a diff, only iv noticed a few differences to the diff thats in my zook at the moment, the diff is stamped with "L21" and has 2 flexible brake lines.
will this diff drop straight in to my 92 wt sierra
more pictures if needed
Post Posted: Sat Dec 17, 2011 1:32 am
It must be an older diff, they used 2 brakelines for the rear. I have seen a HT NT drover with 2 lines. WT use one. So use your old ones.
Make sure the spring spacing on that new housing and total width is WT!
Post Posted: Sat Dec 17, 2011 3:04 am
considering it uses that type of bung , id also be worried about the diff ratio , you would want to check that as well.
Post Posted: Sat Dec 17, 2011 6:25 am
SHiT...... front and rear nt diffs for sale complete brake to brake...
was told they were wt should have checked :cry:
Post Posted: Sat Dec 17, 2011 9:18 pm
Live and learn..
Post Posted: Sat Dec 17, 2011 9:35 pm
Easy way to pick the difference between NT and WT diff housings...
NT front has Ubolt keeper thing halfway up the pumpkin. WT has it on the flat of axle tube.
NT rear has no handbrake in the backing plates, WT does.
NT filler plug is a hex head whereas WT filler plug is recessed 10mm square hole.
Users browsing this forum: No registered users and 92 guests
