Joined: Fri Feb 25, 2011 5:24 am Posts: 77 Location: wa
Posted: Fri Dec 16, 2011 11:44 pm
im rebuilding a diff, only iv noticed a few differences to the diff thats in my zook at the moment, the diff is stamped with "L21" and has 2 flexible brake lines.
will this diff drop straight in to my 92 wt sierra
more pictures if needed
Easy way to pick the difference between NT and WT diff housings...
NT front has Ubolt keeper thing halfway up the pumpkin. WT has it on the flat of axle tube.
NT rear has no handbrake in the backing plates, WT does.
NT filler plug is a hex head whereas WT filler plug is recessed 10mm square hole.
Users browsing this forum: No registered users and 119 guests
