It is currently Thu Aug 06, 2026 10:17 am
Post Posted: Sat Jan 14, 2012 11:33 pm
was hoping someone might be able to help with a wiring issue i am having with my 1.6 conversion into my sj80
i can't seem to get power out of my computer and into my relay's?
checked all earths and all seem ok
any advice would be awesome and alot cheaper then calling an auto elec lol
Post Posted: Sun Jan 15, 2012 12:01 am
What are the relays for??
In majority of the cars on our roads the ECU will switch an earth to a relay not a positive.
Post Posted: Sun Jan 15, 2012 12:24 am
fuel pump relay
and main relay
Post Posted: Sun Jan 15, 2012 1:10 am
Fuel Pump will be switched by the ECU using a negative..
As for the main relay.. Without seeing a diagram I am assuming that it is the main relay that supplies power to the ECU only when the ignition is on. It is usually switched via a positive from an ignition wire.
If the ECU isn't receiving power from the main relay then everything else won't work.
Once again though I have not dealt with g16 wiring before and am only going off a few other engines that I have installed (mainly Nissan Rb, ca, sr and some other ones)
Post Posted: Sun Jan 15, 2012 3:36 am
prob sorted now im getting a really weak spark
distributer cap is a bit crap hoping its the only reason he isn't kicking over
and not another wiring issue
Post Posted: Sun Jan 15, 2012 4:01 am
What was the problem??
Just so others know what to look for.
Users browsing this forum: Google [Bot] and 510 guests
