Posted: Mon Jan 23, 2012 12:50 am
Brown wire on the ecu (note I dont know if there is more than 1 brown wire from the ecu that do other things)
is it the stock tacho? back in the day there used to be problems with some cheaper brand tachos not being able to work with an ecu tach signal as it wasnt as strong as what you would see direct from the coil negative
Users browsing this forum: No registered users and 307 guests
