It is currently Thu Oct 15, 2026 8:19 pm
Post Posted: Mon Jan 23, 2012 6:30 am
I am need of a size of nut that does not seem to exist.
On the firewall of the Jimny they have used threaded studs that are 5mm x 1.5mm pitch. These are used to secure cable clamps and the sound deadning sheet, with plastic nuts. I am using 3 posts to mount my fuse/relay block and would like to secure with metal nuts. Any where I can get some of these? Or blind nuts and a thread tap.
Post Posted: Mon Jan 23, 2012 6:35 am
Rivnuts?
Post Posted: Mon Jan 23, 2012 6:40 am
No idea what Rivnuts is.
Vehicle: 1985 Holden Drover
Post Posted: Mon Jan 23, 2012 7:06 am
http://lmgtfy.com/?q=rivnut
1989 WT Sierra.
Post Posted: Mon Jan 23, 2012 7:49 am
http://auszookers.com/index.php?name=Fo ... ht=nutsert
Vehicle: WT Tinny, NT lwb, 1L lwb
Post Posted: Mon Jan 23, 2012 10:41 am
Got a tap and die set? Make a new "easy to find nuts" thread
JrZook - Mine only hangs 2.5".
 Profile WWW ICQ YIM
Post Posted: Mon Jan 23, 2012 11:15 am
Ok, yes I know what nutserts are and I have a borrowed kit in my posession atm. I have used a few, but these aren't what I am after.
There is a threaded stud coming out from the firewall and I want a nut to suit to replace the plastic clips and nuts. I did consider retapping, but that would destroy half of what is there and leave little material.
Here is one of the clips and posts in question.
I've actually removed those clips and am planning on using rubber lined hose clamps.
Post Posted: Sun Jan 29, 2012 7:41 pm
8O. Is that a fuse box?
Post Posted: Sun Jan 29, 2012 9:02 pm
Its not real thread form but have seen steel pressed sheet metal hex nuts that will fit.
On 80'ish cars usually hanging on to trim or in under dash applications, but they are not much
better than plastic nuts you've got. Use some M5 coarse Brass hex nuts, force than on with
loctight. Use 2 per stud if possible, better than rubber line hose clamps and should be able to
remove than later.
Post Posted: Sun Jan 29, 2012 9:04 pm
This jimny just keeps getting better!
Users browsing this forum: No registered users and 354 guests
