It is currently Wed Oct 14, 2026 3:41 am
Post Posted: Thu Jan 26, 2012 1:03 am
I know upgrading alternators has been discussed in the forums but I am unable to find anything specific for the G16B. Could anyone advise what alternator would easily fit increasing the output and what I would need for this... bracket, plugs etc...
I did purchase a 2nd hand Ford 110amp but I think its the wrong version?!
Much appreciated!
The Zooks of Hazzard
Post Posted: Thu Jan 26, 2012 9:33 am
I haven't done the ford one, but Piranha do a kit for them.
It's not cheap though, about $400 I think
4X4 For Work And Play!
Vehicle: 91 Tin Top, 04 Jimny
Post Posted: Thu Jan 26, 2012 10:32 am
What's wrong with the ford alt? Is it a ef/el?
Post Posted: Thu Jan 26, 2012 7:46 pm
Ford all the way. No reason to look at anything else.
I assume the G16B is in a sierra based on your avatar? It's a nightmare to fit a bigger alternator onto a G16B in a vitara, but it is possible.
Post Posted: Thu Jan 26, 2012 9:13 pm
That's correct Steve, it is in a Sierra.
On further investigation I was sold the incorrect unit and ended up with an AU Ford alternator instead!
I'm guessing the EL version is what I'm after? Anything else I will need to go with it?
Post Posted: Thu Jan 26, 2012 9:29 pm
Have a good read of this Alt. Upgrade
JrZook wrote:
4wheeljive wrote:
is this going to work on a g16b???
Yes! But I found is you use the stock cast mount on the g16B the alternator will be wayyy off alignment. Find a 1.3 metal alternator bracket and drill it out.
Dan
Ripped straight from there regarding G16
Post Posted: Thu Jan 26, 2012 10:21 pm
Awesome! Thanks Boneheimer :)
Users browsing this forum: No registered users and 323 guests
