| Author |
Message |
hobble
Joined: Tue Jul 05, 2011 10:52 pm Posts: 52 Location: brisbane
 Posted: Mon Feb 27, 2012 9:01 am |
hi guys i have a 1985 sierra ute with a gti engine in it its alot better than the std sierra engine but still need more power what is the biggest engine you can put in a sierra in qld and be legal im thinking of ca18 or sr20 not worried about the weight of the engine
any help would be great thanks
stewy91
Joined: Thu Aug 26, 2010 11:16 am Posts: 287 Location: deception bay
 Posted: Mon Feb 27, 2012 9:12 am |
Talk to a engineer or why not turbo yours if your really want more power
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Mon Feb 27, 2012 9:21 am |
Do you want more power or torque?? Why not a 1.6 EFI Vit engine?
_________________ Shep is a closet jimny lover!!!!
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Mon Feb 27, 2012 9:39 am |
hobble wrote: what is the biggest engine you can put in a sierra in qld and be LEGAL hobble wrote: im thinking of ca18 or sr20 not worried about the weight of the engine
To be a legal conversion YOU NEED TO WORRY ABOUT THE WEIGHT.
Hybrid
Joined: Mon Apr 21, 2008 11:30 pm Posts: 1095 Location: Bulimba, Brisbane
Vehicle: '92 Sierra
 Posted: Mon Feb 27, 2012 9:45 am |
Most do the g16 swap out of a vitara. More torque at lower revs than the GTI from what I hear but I have a feeling it's not the kind of jump in power you're after.
If you do a search on here you'll find guys that have run the CA18, 4age and 4agze. I can't remember if it was on this forum but there's been a bit of talk about SR20DETs too. Go to your engineer and see what he will allow. Simple as that. Apart from the G16 they'd all be a massive pain in the butt to fit.
atari4x4
 Posted: Mon Feb 27, 2012 10:06 am |
running larger than stock tyres?
maybe look at buying transfer gears first.... cheaper & smarter than doing another engine swap.
GRPABT1
Joined: Mon Nov 19, 2007 10:30 pm Posts: 731 Location: Townsville
 Posted: Mon Feb 27, 2012 11:02 am |
If it's power you're after then a turbo GTi setup makes more sense in a Sierra than in a swift as swifts have weak boxes. I've been in a turbo GTi Sierra and honestly it's down right scary, way more power than a Sierra ever needs.
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Mon Feb 27, 2012 11:06 am |
GRPABT1 wrote: If it's power you're after then a turbo GTi setup makes more sense in a Sierra than in a swift as swifts have weak boxes. I've been in a turbo GTi Sierra and honestly it's down right scary, way more power than a Sierra ever needs. So you reckon a sierra gearbox is strong?
_________________ 2013 GV 1998 SV420 ute
masterA
Joined: Tue Jan 18, 2011 3:24 am Posts: 976 Location: Perth
 Posted: Mon Feb 27, 2012 2:03 pm |
Depends how deep your pockets are you can pretty much do anything
Whichever way you go, the engine will need to be engineered Most of the engines you spoke about will definatelly need new engine mounts, probably gearbox mounts too as well as custom tail shafts etc etc Wiring and misc bits and pieces and you won't get much change out of $5K
Why not just turbo the GTi engine if it's already engineered?!
Another thing to keep in mind is running too much power through the sierra drivetrain isn't such a good idea That means beefed up axles, centre's uni's etc.....costs just keep adding up....
_________________ Fast,Cheap,Reliable-Pick 2 & 3rd is laughable
GRPABT1
 Posted: Mon Feb 27, 2012 2:48 pm |
Fatzook wrote: GRPABT1 wrote: If it's power you're after then a turbo GTi setup makes more sense in a Sierra than in a swift as swifts have weak boxes. I've been in a turbo GTi Sierra and honestly it's down right scary, way more power than a Sierra ever needs. So you reckon a sierra gearbox is strong?  Heaps stronger than a GTi box, and option to run some strong auto's too. I've often dreamt of a trimatic backed turbo GTi powered Sierra drag car, no transfer, Hilux diff, easy 11's I reckon probably 10's with some gas.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Mon Feb 27, 2012 6:44 pm |
turbo gti
_________________ ...
ridzilla
Joined: Mon Sep 26, 2011 11:27 am Posts: 306 Location: Western Australia
Vehicle: '91 Sierra, Fluffy Dice.
 Posted: Mon Feb 27, 2012 7:07 pm |
If you swap it out, I'll buy your old engine
_________________ If at first you don't succeed, get a bigger hammer
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13016 Location: Melbourne
 Posted: Mon Feb 27, 2012 7:35 pm |
Is it geared right? If so, you must have the best handling Sierra ever because 100hp should be enough to be scary.
If you need ore than 100hp in a Sierra you might need to trade to something bigger- the Sierra drivetrain isn't going to live long with more than 100hp/ turbo torque in front of it.
Steve
superduki
Joined: Thu Nov 05, 2009 10:30 pm Posts: 466 Location: Tasmania
 Posted: Mon Feb 27, 2012 7:42 pm |
GRPABT1 wrote: Fatzook wrote: GRPABT1 wrote: If it's power you're after then a turbo GTi setup makes more sense in a Sierra than in a swift as swifts have weak boxes. I've been in a turbo GTi Sierra and honestly it's down right scary, way more power than a Sierra ever needs. So you reckon a sierra gearbox is strong?  Heaps stronger than a GTi box, and option to run some strong auto's too. I've often dreamt of a trimatic backed turbo GTi powered Sierra drag car, no transfer, Hilux diff, easy 11's I reckon probably 10's with some gas. Hmm my turbo GTi runs a standard GTi gearbox with a phantom grip lsd in it. I've ran anywhere between 10-22 pound through it, including the complete 2008-2009 drag season, making every meet, and the only problem I ever have/had was bearing failure (big deal, common fixes for bigger input bearings), and the cross pin coming out of the centre. That was due to too many one wheeler burnouts, causing the cotter pin in the cross pin to snap, letting the cross pin come out @145 km/h and lunching my clutch and inside of the 'bellhousing' area of the box. With a locker in it now, no dramas. I know those boxes inside out. They are absolutely identical to a barina box, except the final drive ratio is different, and an extra bolt webbing on the casing itself, they certainly aren't that weak, considering the raping I give and expect of it. Sierra gearboxes, hmm I've broken a couple now, standard motors in front of them, mate had a 4a/7age hybrid thing mated to a sierra box, and fcked them out all the time. They certainly aren't a strong gearbox with more power. But on a positive note, your dream you often have, I am surprised that their isn't alot of 2wd Sierra's floating about, with a nuts drivetrain in them.
_________________ GTi Turbo & A LWB Sierra.
hobble
 Posted: Tue Feb 28, 2012 3:48 pm |
my problem is most likely my gearing is out but my speedo is only out by a 2-3 kms i have just put in 3.9 diffs out of a coily front and rear just centers and now i have put on some 30'' tyres driving around town is fine but when i get on the highway and there is a hill or head wind i have to back to 4th then i can do 90kms so i was thinking something with more power would be good i didnt think TC gears would make that much of a difference
atari4x4
 Posted: Tue Feb 28, 2012 3:55 pm |
what size tyres are you running?
royce
 Posted: Tue Feb 28, 2012 4:08 pm |
You can put gears out of a coily into a leaf sierra, if yors was a 1.3 to begin with it already had 3.9 in it
Youve also not mentioned your transfer gearing, stock gearing with bigger tyres will alsways suck with a little engine, mo matter how cool they were in 1992
GRPABT1
 Posted: Tue Feb 28, 2012 9:09 pm |
superduki wrote: GRPABT1 wrote: Fatzook wrote: GRPABT1 wrote: If it's power you're after then a turbo GTi setup makes more sense in a Sierra than in a swift as swifts have weak boxes. I've been in a turbo GTi Sierra and honestly it's down right scary, way more power than a Sierra ever needs. So you reckon a sierra gearbox is strong?  Heaps stronger than a GTi box, and option to run some strong auto's too. I've often dreamt of a trimatic backed turbo GTi powered Sierra drag car, no transfer, Hilux diff, easy 11's I reckon probably 10's with some gas. Hmm my turbo GTi runs a standard GTi gearbox with a phantom grip lsd in it. I've ran anywhere between 10-22 pound through it, including the complete 2008-2009 drag season, making every meet, and the only problem I ever have/had was bearing failure (big deal, common fixes for bigger input bearings), and the cross pin coming out of the centre. That was due to too many one wheeler burnouts, causing the cotter pin in the cross pin to snap, letting the cross pin come out @145 km/h and lunching my clutch and inside of the 'bellhousing' area of the box. With a locker in it now, no dramas. I know those boxes inside out. They are absolutely identical to a barina box, except the final drive ratio is different, and an extra bolt webbing on the casing itself, they certainly aren't that weak, considering the raping I give and expect of Sierra gearboxes, hmm I've broken a couple now, standard motors in front of them, mate had a 4a/7age hybrid thing mated to a sierra box, and fcked them out all the time. They certainly aren't a strong gearbox with more power But on a positive note, your dream you often have, I am surprised that their isn't alot of 2wd Sierra's floating about, with a nuts drivetrain in them. I've got a few mates with worked GTi's and all of them have habgearbox dramas, the one turbo one of the three did 5 boxes in 6 months before he got the shits and sold it. On Redline GTi people don't seem to share your faith in the stock boxes haha. That said, a trimatic is standard fitment in an auto Sierra and they can be built to handle about 400-500hp, a custom converter would be needed though. End hijack.
hobble
 Posted: Wed Feb 29, 2012 8:40 am |
yes that would be right about the diffs but i have wt diffs in it stock TC gears from a wt might put the stock tyres on and see how she goes it just a pain having to go back to 4th and then still can only do 90 kms my mini moke with a 1L in it is better than my suzuki
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Wed Feb 29, 2012 9:24 am |
atari4x4
 Posted: Wed Feb 29, 2012 9:36 am |
i'll ask for a 3rd time, what size tyres are you running?
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Wed Feb 29, 2012 1:31 pm |
Suzukis will never be a fast car. however a geared gti sierra on decent rubber gets along well.110 up hill etc.
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
hobble
 Posted: Wed Feb 29, 2012 4:16 pm |
sorry im running 30" tyres
masterA
 Posted: Wed Feb 29, 2012 4:32 pm |
Your problem isn't the engine....its big tyres with no gearing Put a set of stock tyres and see what happens
rummy1
 Posted: Wed Feb 29, 2012 8:19 pm |
hobble wrote: hi guys i have a 1985 sierra ute with a gti engine in it its alot better than the std sierra engine but still need more power what is the biggest engine you can put in a sierra in qld and be legal im thinking of ca18 or sr20 not worried about the weight of the engine
any help would be great thanks if ya want more power, i have a turbo here off a honda city that might tickle your fancy. its a ihi rhb 31 unit that normally runs 10psi on the honda, so it should have a bit of kick for a suzuki engine (might want to back the boost off a little though)
