It is currently Tue Oct 27, 2026 5:08 pm
Vehicle: 1995 suzuki sierra hardtop
Post Posted: Sun Mar 04, 2012 3:16 pm
Can someone confirm this for me. From my understanding the pcv should be open at idle and closed at full throttle. So if I put my finger on the valve there should be a noticeable drop in suction as I increase the revs , is that right??
Post Posted: Sun Mar 04, 2012 5:19 pm
PCV is a one way valve.
It allows the inlet to suck out crankcase pressure/fumes/oil.
If you have pressure at the pcv at idle, revs will only increase it.
Piston ring blow-by is the usual cause.
Post Posted: Sun Mar 04, 2012 5:23 pm
As you increase the revs there is less vacuum in the manifold, hence less suction through the PCV. The PCV tends to get a bit clogged with oil over time, a bit of brake clean easily cleans it out.
Vehicle: chick magnet coily
Post Posted: Sun Mar 04, 2012 6:47 pm
catch can man :blingbling:
when in doubt... HOLD IT PINNED!!! :)
Vehicle: 1995 soft top vitara
Post Posted: Mon Mar 12, 2012 8:16 pm
is there any need to have one if you have a catch can>?, i replaced my tapet cover gasket on my turbo engine and there was a busted pcv valve sitting in there. no damage done, that i could see. should i replace it
turbo vitara, fark yeah.
Users browsing this forum: No registered users and 247 guests
