Joined: Thu Jan 19, 2012 8:48 am Posts: 73 Location: Victoria
Vehicle: 1995 suzuki sierra hardtop
Posted: Sun Mar 04, 2012 3:16 pm
Can someone confirm this for me. From my understanding the pcv should be open at idle and closed at full throttle. So if I put my finger on the valve there should be a noticeable drop in suction as I increase the revs , is that right??
As you increase the revs there is less vacuum in the manifold, hence less suction through the PCV. The PCV tends to get a bit clogged with oil over time, a bit of brake clean easily cleans it out.
Joined: Sat Nov 14, 2009 10:30 pm Posts: 246 Location: glasshouse mtns
Vehicle: 1995 soft top vitara
Posted: Mon Mar 12, 2012 8:16 pm
is there any need to have one if you have a catch can>?, i replaced my tapet cover gasket on my turbo engine and there was a busted pcv valve sitting in there. no damage done, that i could see. should i replace it
Users browsing this forum: Google [Bot] and 331 guests
