It is currently Tue Oct 20, 2026 9:45 am
Vehicle: MG410 1.6efi broken rear diff
Post Posted: Fri Mar 16, 2012 1:01 pm
Hi All
I have a issue in rear locked diff were I occasionally lose forward motion,(just ratchet noise) then it will lock usually happens in slow take off situations.
When I raise either wheel I can freely spin wheel forward and reverse and get clear ratchet noise,with occasional lock on left side wheel.I still have diff engagment for normal driving with No abnormal noises.
Want33 said it meight be locker drive pin in another post which I think he could be right,as I'm not in a area where stripping diff would be wise why I still have drivability.
Has anyone experienced a similar issue or have a opinion as I'm trying too cover most options as it looks like it meight be a order from USA for Spartan Parts and prefer not to be waiting for long period for parts whonce diff is removed.
Thanks
Ian
Vehicle: 2004 SQ625 GV
Post Posted: Fri Mar 16, 2012 3:58 pm
My locker played around like that when I first installed it and I had to add more shims to the side gears and take some meat off the pinion block to get it to work.
Post Posted: Fri Mar 16, 2012 4:04 pm
Yep, you'd shimming is out, so there is enough room in your center for both sides to disengage and just spin.
With a wheel in the air you should be able to doing it freely, it doesn't 't have positive force put through it, only when there is force on it will it bind up.
Be prepared to do this every 5000-10000kms due to auto lockers being agricultural pieces of equipment that destroy uni's, backlash, bearings, shimming and gears. The only way I would run an auto lockers is shimmed up so tight it never disengages.
Vehicle: 1985 Holden Drover
Post Posted: Fri Mar 16, 2012 4:58 pm
Makes me wonder why shims werent provided with the spartan i ordered then...
1989 WT Sierra.
Post Posted: Fri Mar 16, 2012 5:09 pm
Spartans don't use any shims.
And you do need to make sure the side gear thrust washers are removed.
May not be a locker issue, tho not sure what it would be.
Post Posted: Fri Mar 16, 2012 5:15 pm
The 4 small pins can bind a bit when new,
if thats the issue, it should come good.
Post Posted: Fri Mar 16, 2012 5:29 pm
So thats two for shims and one for no shims. This is why i get confused :lol:
1989 WT Sierra.
Post Posted: Fri Mar 16, 2012 5:35 pm
I can confuse myself without any help :oops:
Post Posted: Fri Mar 16, 2012 6:02 pm
Yes its confusing,I should note locker has been in for 35000km just replaced side gears 5000km ago.
Everything was Okay until I did a right hand U turn on hard surface in which the diff binded causing a very load bang.On further inspection my rear left wheel nuts were lose with only few turns left.
Once tighten everything seemed okay except locker (diff) doesn't engage just a ratched noise,with low ratchet noise on turns as usual.
Before I couldn't freely spin wheel why the other wheel was in contact with ground as the couplings should be locked especially with drive shaft still attached.
If I have broken pins I have no differential action at all,damged springs and pins maybe but torque should force lock engagment and if broken side gear one axel should still be still engaged.
Its got me stumped so looks like 500km trip to strip diff
Post Posted: Fri Mar 16, 2012 6:16 pm
Has anyone ever broken the Differential Pin Retainer Block
Post Posted: Sun Mar 18, 2012 2:57 pm
x2 for shims. Mines due to be done next time I pull it apart.
Vehicle: Yamaha scooter, 50cc
Post Posted: Mon Mar 19, 2012 4:47 pm
Spartans aren't the same as lock-rights, I'm pretty sure there's no shims in a Spartan (at least there isn't in mine)
Post Posted: Mon Mar 19, 2012 4:57 pm
You can add shims behind the side gears to tighten it up.
Post Posted: Mon Mar 19, 2012 9:18 pm
I have rear left traction (power) and no right side traction (idle) in mud,so I'm guessing right rear side gear failure.
So now to find a side gear
Post Posted: Tue Mar 20, 2012 9:46 am
There was none with my lockrite either. But the center your putting it into has probs had a hard life, and it worn. So if you bought a new center from Suzuki the Spartan would be spot on, but wear and tear mean it's probs not going to behave like you would expect...
You might have broken an axle goldpoacher. Which could mean that you axle is just sitting in you housing.... Would be interesting to know what the final result is.
Post Posted: Tue Mar 20, 2012 11:15 am
How would I go about testing for what size shims I need to install when I get around to putting my locker in? Or is it more like a put it in and test it kinda deal?
1989 WT Sierra.
Post Posted: Tue Mar 20, 2012 11:18 am
Dont use any with a brand new locker. They are tight from the get go and eventually wear in. Mines been in for a year now and its still working well but i want it a little tighter for powering through corners where it tends to freak out.
Post Posted: Tue Mar 20, 2012 1:50 pm
You install it without the springs, use a dial gauge, measure the movement, insert shim that takes up the room.
That's a super simple way of putting it.
And dan, if the actuahosier center is worn then won't the brand-new locker still need shimming?
Post Posted: Tue Mar 20, 2012 2:05 pm
Not that i found. Mine was a spool that went BANG when the tyres were at 10psi where there was enough traction to force it unlocked. Over time it loosened up.
Last time i had it out, i chucked in some very small shims which took up some of the slack after it wore.
Its spot on now. I only get chirpies when im foot to the floor. Not even carparks or servos etc, only click click click click
Users browsing this forum: Google Adsense [Bot] and 236 guests
