It is currently Sun Nov 01, 2026 4:59 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Thu Apr 05, 2012 9:37 am
Im having trouble getting the bolt undone. is it left hand or right hand thread?
Post Posted: Thu Apr 05, 2012 11:42 am
regular thread. i used a 3/4in rattle gun to get mine out. Tough bastard, try heating if you can but impact is your best bet :) good luck mate.
tintop, barwork, locked Front , RUF, 4.9's, 31's :
Post Posted: Thu Apr 05, 2012 12:11 pm
thanks I thought it was. Boy is it tight
Vehicle: 93 vitara estate
Post Posted: Wed May 02, 2012 6:32 pm
Best way is to get 17 mm socket on a breaker bar and lock it into place and give your key a quick turn, works every time
Post Posted: Wed May 02, 2012 6:54 pm
WITH THE IGNITION LEAD DISCONNECTED!!!!!
Post Posted: Wed May 02, 2012 7:47 pm
Yeah got it. Hardest bit was holding the engine still (wasnt in a car) I used two 4m bars to get it undone. Anyway the block and crank I scored are in good nick
Post Posted: Thu May 03, 2012 10:49 am
What happens I'd u don't disconnect ignition lead I dont
Post Posted: Fri May 04, 2012 9:04 pm
engine runs, so you screw everything up
Post Posted: Fri May 04, 2012 9:08 pm
Further to this....
The engine starts, and runs. What happens next can range from nothing at all, to someone or something getting nailed by a rapidly moving breaker bar and 17mm socket.
You don't need ignition, you just need the motor to crank over on the starter a few turns. :wink:
Post Posted: Sat May 05, 2012 10:08 am
thats what i mean u just tick the key so it cracks the bolt pretty simple
Users browsing this forum: Google [Bot] and 68 guests
