| Author |
Message |
DSKEW3
Joined: Sun May 22, 2011 12:05 pm Posts: 80 Location: sunshine coast
 Posted: Thu Apr 05, 2012 3:28 pm |
just received my lift kit and was wondering if it was a hard job to do at home???
atari4x4
 Posted: Thu Apr 05, 2012 3:34 pm |
is this where we guess what type of suzuki you own?
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Thu Apr 05, 2012 3:36 pm |
im thinking Jimny, or a patrol as no one else would put 80mm of lift in a car and think its a good idea.
Parr
Joined: Mon Nov 07, 2011 3:08 am Posts: 27 Location: Hervey bay
 Posted: Thu Apr 05, 2012 3:40 pm |
Trolly jack and some car stands, basic had tools and a basic mechanical knowledge. If you open up the kit and dont no what the parts are, were they go or how to get them in there, I would take it to a professional.
Are you doing brake lines and all that jazz or just springs, shocks and panhards?
ps dont forget you steering wheel will no longer be straight until you do an alignment
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu Apr 05, 2012 3:42 pm |
My steering wheel is a circle
_________________ mlm
DarkHorse
 Posted: Thu Apr 05, 2012 5:25 pm |
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Thu Apr 05, 2012 5:38 pm |
It's a really easy job if you're mechanically apt. I did 4 coils today and the rear three times in two hours playing with different coils and spacers. The hardest part is getting it jack up and supported safely. If you don't have good stands and jacks you should probably avoid doing it yourself. Don't put 80mm of lift until you have longer brake lines.
_________________ Click WWW below for STICKERS
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Thu Apr 05, 2012 6:44 pm |
tanshi wrote: im thinking Jimny, or a patrol as no one else would put 80mm of lift in a car and think its a good idea. So much truth here. Steve.
Mike57
Joined: Fri Jul 22, 2011 11:09 am Posts: 1009 Location: Melbourne
Vehicle: Suzuki Jimny 2009
 Posted: Thu Apr 05, 2012 7:10 pm |
Tanshi is a bit hard on the Jimny owners?
brindog
Joined: Sun Oct 18, 2009 10:30 pm Posts: 1139 Location: Uki NSW
 Posted: Thu Apr 05, 2012 7:32 pm |
Trolly jack and jack stands, easy as. Remove the wheels for easy access and so you can drop the diff lower. If you don't have stands or trolly jack go and buy some, you'll use them quite a bit anyway, so they will pay themselves off quickly. zukenutter wrote: Don't put 80mm of lift until you have longer brake lines. Extended brake lines are not a must to fit before fitting the lift. With the rear, you can stretch the lines enough to remove and fit the new coils. But with the front you need to disconnect them so you can drop the diff low enough. Easy to do, just re-attach and bleed. You can use them until you get extended ones, just don't flex it up.
_________________ zukenutter wrote: Here you go Atari, stick that in your mangina
GRPABT1
Joined: Mon Nov 19, 2007 10:30 pm Posts: 731 Location: Townsville
 Posted: Thu Apr 05, 2012 9:27 pm |
Or don't hit a decent pothole, get to much body roll round a corner, get some lift off of a crest in the road..... That is unless you want to be ploughing into whatever is in front of you next moment you need to stop.
The practice described above by brindog is down right dangerous, I'd only do that if it were to drive onto a trailer to head down to the nearest brake shop to get longer lines fitted.
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Thu Apr 05, 2012 9:40 pm |
brindog wrote: Trolly jack and jack stands, easy as. Remove the wheels for easy access and so you can drop the diff lower. If you don't have stands or trolly jack go and buy some, you'll use them quite a bit anyway, so they will pay themselves off quickly. zukenutter wrote: Don't put 80mm of lift until you have longer brake lines. Extended brake lines are not a must to fit before fitting the lift. With the rear, you can stretch the lines enough to remove and fit the new coils. But with the front you need to disconnect them so you can drop the diff low enough. Easy to do, just re-attach and bleed. You can use them until you get extended ones, just don't flex it up. I went 6months with out extended brake line's - never had a issue As other have said, jack stands, trolley jack and spanner's/socket's etc....away you go. I can swap 4 coils and 4 shocks in less than a 1 hour now with just those basic tools  I've only done it a dozen time's now tanshi wrote: im thinking Jimny, or a patrol as no one else would put 80mm of lift in a car and think its a good idea. Care to elaborate please?
_________________ Tell my arse, he actually gives a crap!
BertZook
Joined: Wed May 26, 2010 3:01 am Posts: 2979 Location: Sunshine Coast
 Posted: Fri Apr 06, 2012 1:14 am |
monley wrote: As other have said, jack stands, trolley jack and spanner's/socket's etc....away you go. but about the caster bushes  it shouldnt have a special tool for it??
_________________ "BertZook's Jimny needs mods fundraiser"
dirtydogz
Joined: Thu Nov 10, 2011 8:52 pm Posts: 24 Location: high wycombe u.k
 Posted: Fri Apr 06, 2012 7:10 am |
If you got a set of longer brake hoses fit them first this is only with the 3"lift, not needed on the 2" lift. You will also need to fit caster correction bushes+rear shock brackets . Next (WD40)all the nuts and bolts on the shocks for about 2 days before starting. Start with the back axle,undo the wheel nuts a little,then jack up on the chassis on both sides and lower on to axle stands as near to the radius arms as possible , so the tyres are about 2" off the ground,now remove the wheels. Next place the trolley jack in the middle of the axle, jack it up so you can remove the nuts+bolts from the shocks. Next lower axle down and remove the old springs+shocks, you might need a mate to help you fit the new springs+shocks back on, or a length of wood to lever the axle down to get the new springs on. Now do the the front the same way as the back. When your finished CHECK all the nuts +bolts+ wheel nuts are tight. Attachment: thumb_bracket2[1].jpg Attachment: Copy3ofIMG_0002.jpg
zukenutter
 Posted: Fri Apr 06, 2012 7:40 am |
BertZook wrote: monley wrote: As other have said, jack stands, trolley jack and spanner's/socket's etc....away you go. but about the caster bushes  it shouldnt have a special tool for it?? Oh yeah, hydraulic press for caster bushes.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri Apr 06, 2012 8:35 am |
tanshi wrote: im thinking Jimny, or a patrol as no one else would put 80mm of lift in a car and think its a good idea. Jimny's are lower then a Sierra stock for stock, and 80mm more track. So if a Sierra owner has a 25mm BL, and 50mm lift springs, and a jimny owed puts in 80mm of lift it wouldn't be as high as a Sierra and wider then a Sierra. Jimny's are going to blow up like sierras, it will all take time
SierraDan
 Posted: Fri Apr 06, 2012 9:46 am |
You've changed
joel
Joined: Wed Jan 27, 2010 10:30 pm Posts: 2191 Location: Dirranbandi
Vehicle: Sj70 tintop
 Posted: Fri Apr 06, 2012 9:53 am |
31zook wrote: tanshi wrote: im thinking Jimny, or a patrol as no one else would put 80mm of lift in a car and think its a good idea. Jimny's are lower then a Sierra stock for stock, and 80mm more track. So if a Sierra owner has a 25mm BL, and 50mm lift springs, and a jimny owed puts in 80mm of lift it wouldn't be as high as a Sierra and wider then a Sierra. Jimny's are going to blow up like sierras, it will all take time  im hopping on the jimny bandwagon!
_________________ Sj70 tintop
SierraDan
 Posted: Fri Apr 06, 2012 11:40 am |
Jimny Front: 1355 mm Rear: 1365 mm
Sierra WT Front 1340mm Rear 1350mm
That 15mm wouldnt count for that extra height i dont think..
31zook
 Posted: Fri Apr 06, 2012 11:45 am |
Where did you get those from dan?
SierraDan
 Posted: Fri Apr 06, 2012 11:49 am |
viewtopic.php?f=17&t=7678RIKSTR wrote: Sierra WT Front 1340mm Rear 1350mm neofitou wrote: Jimny Front: 1355 mm Rear: 1365 mm Wheel Base: 2250mm
31zook
 Posted: Fri Apr 06, 2012 3:25 pm |
That's weird, I was only going off the fact that WT long side and Jim long side axles are 40mm different, so I figured it would be either side...
I might have to keep searching for Jim spec's cause they don't seem right to me...
SierraDan
 Posted: Fri Apr 06, 2012 3:34 pm |
31zook
 Posted: Fri Apr 06, 2012 3:41 pm |
So do a few other websites.... Maybe the front pumpkin is offset 40mm one way
SierraDan
 Posted: Fri Apr 06, 2012 3:43 pm |
Yeah thats what i was thinking. Shorter short side?
BertZook
 Posted: Fri Apr 06, 2012 7:35 pm |
the width wont be as much, but we still have a bit of a longer wheel base too
SierraDan
 Posted: Fri Apr 06, 2012 8:37 pm |
Okay...
neofitou
Joined: Wed Mar 24, 2010 10:30 pm Posts: 1088 Location: Melbourne
Vehicle: 00 Jimny, 63 Haffy
 Posted: Fri Apr 06, 2012 8:41 pm |
I'm looking forward to getting back to Au and building a big Jimny, I don't think there will be much Jimny left though, none of the driveline will stay..
I'm still only going to have about 50mm of suspension lift max. I agree, yes Jimnys are lower and wider than Sierras, but it doesnt mean sticking in wobbly 80mm lift is a good idea, but they sell them the op's question as to how hard they are to install
It's pretty much been established that it's not hard and can easily be achieved with basic tools, however at a minimum: longer brake lines and caster correction will be needed for this lift as well as adjustable panhards being a good idea.
I hope that others come across this thread and think twice before buying an 80mm lift kit as thier first attempt and modifying thier car, but I'm too drunk right now to be posting on forums right now and to be more useful with the debate as to why.
monley
 Posted: Fri Apr 06, 2012 9:30 pm |
I dont see what's with all hate on the 80mm lift
BertZook
 Posted: Fri Apr 06, 2012 9:40 pm |
monley wrote: I dont see what's with all hate on the 80mm lift  me neither they all are "yeh 50mm its perfect pppfff I mean cmon.... but 80mm that sh&* crazy!!!!!!!!!!"..... ve u guys grab a ruler and actually see wht 30mm actually look like and yeh of course a sierra with 2"lift and 1" of BL is acceptable... or with just with either the 2" lift or body...... but a 3" lift on a jimny is crazy???...
