It is currently Tue Sep 22, 2026 11:09 pm
Post Posted: Thu Apr 19, 2012 1:51 pm
hey guys, just another noobish question. i have a 1992 Suzuki sierra 1.3L. I have done a radiator flush out, and re field it with coolant and it all the coolant was gone the next day, so i flushed it out again and re topped it up and its been 2 says since i have done that and i just got back from a drive and its once again out off coolant, has anyone got any idea what could be causing it?. I think it could have a blown head casket because it is also blowing some smoke and is miss firing for about 5mins after starting it but not too sure.
any help would be great thanks.
Post Posted: Thu Apr 19, 2012 2:05 pm
Head gasket or cracked head/block would be my guess. Does your engine oil have a milky tinge to it??
Post Posted: Thu Apr 19, 2012 2:14 pm
yeah the oil is a bit milky
Post Posted: Thu Apr 19, 2012 2:19 pm
Dead head gasket or cracked block.
Post Posted: Thu Apr 19, 2012 2:41 pm
Cheap fix....Chemiweld and oil change
bye
Post Posted: Thu Apr 19, 2012 2:46 pm
bye
If its using that much water I doubt chemiweld would do anything
Post Posted: Thu Apr 19, 2012 2:52 pm
yeah i got some knew oil and chemiweld just before and going to try that first, i have a spare head casket so if this doesnt work thats the next thing and then the head
Post Posted: Thu Apr 19, 2012 3:09 pm
dont put chemiweld in if you have a gasket, do it properly if your going to keep it, on use chemiweld as a last resort and you're flogging it off
Post Posted: Thu Apr 19, 2012 3:42 pm
And if your keeping it get the had crack tested and checked for straightness. Also, replace the timing belt and water pump while your in there :peaceout:
Vehicle: SJ80, SE416
Post Posted: Thu Apr 19, 2012 4:53 pm
Rusho wrote:
bye
My coily with a cracked G16a (actually 2 different cracks) in it would empty the overflow tank after an hours driving.
After a chem-i-weld treatment as per the instructions it is fine even a year later, but it doesn't get driven much anymore.
Originally, it always used a small amount of water but the crack became worse after a couple of radiator flushes. I suspect it had had a similar treatment before.
I have also put chem-i-weld into my LWB Vitara. I discovered it had a cracked block when it did a headgasket but it definitely isn't using water now.
Post Posted: Thu Apr 19, 2012 5:46 pm
are you bleeding the system after flush?
Post Posted: Thu Apr 19, 2012 10:21 pm
Oh, in that case chem-i-weld won't fix that (according to the instructions anyway)...
Post Posted: Thu Apr 19, 2012 10:36 pm
Chemiweld is the devil.
helloo
Post Posted: Fri Apr 20, 2012 12:31 pm
My wife had a sigma a few years ago
That leaked green coolant out the tail pipe as fast as u could pour it in
I cheme welded that up and it lasted 18 months
Then I did it again and sold the car 6 months later
Post Posted: Fri Apr 20, 2012 12:53 pm
3 tubs of chemiweld in a TB42 GQ & it was like new again, well new enough to sell. Armsup
Post Posted: Fri Apr 20, 2012 12:54 pm
Not buying anything from you then..
Post Posted: Fri Apr 20, 2012 1:48 pm
done oil change and flushed radiator out again put knew coolant in and chemiweld now just too wait and see what the turn out is. cheers for all help
Users browsing this forum: Google [Bot] and 224 guests
