| Author |
Message |
haurp00ned
Joined: Sat Sep 03, 2011 10:12 pm Posts: 161 Location: coolum beach
 Posted: Thu Apr 19, 2012 1:51 pm |
hey guys, just another noobish question. i have a 1992 Suzuki sierra 1.3L. I have done a radiator flush out, and re field it with coolant and it all the coolant was gone the next day, so i flushed it out again and re topped it up and its been 2 says since i have done that and i just got back from a drive and its once again out off coolant, has anyone got any idea what could be causing it?. I think it could have a blown head casket because it is also blowing some smoke and is miss firing for about 5mins after starting it but not too sure. any help would be great thanks.
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Thu Apr 19, 2012 2:05 pm |
Head gasket or cracked head/block would be my guess. Does your engine oil have a milky tinge to it??
_________________ Shep is a closet jimny lover!!!!
haurp00ned
 Posted: Thu Apr 19, 2012 2:14 pm |
yeah the oil is a bit milky
Fatzook
 Posted: Thu Apr 19, 2012 2:19 pm |
haurp00ned wrote: yeah the oil is a bit milky Dead head gasket or cracked block.
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Thu Apr 19, 2012 2:41 pm |
Cheap fix....Chemiweld and oil change
bye
Rusho
 Posted: Thu Apr 19, 2012 2:46 pm |
cairns27 wrote: Cheap fix....Chemiweld and oil change
bye If its using that much water I doubt chemiweld would do anything
haurp00ned
 Posted: Thu Apr 19, 2012 2:52 pm |
yeah i got some knew oil and chemiweld just before and going to try that first, i have a spare head casket so if this doesnt work thats the next thing and then the head
bakerboy
Joined: Sun Oct 25, 2009 10:30 pm Posts: 2291 Location: Perth
 Posted: Thu Apr 19, 2012 3:09 pm |
dont put chemiweld in if you have a gasket, do it properly if your going to keep it, on use chemiweld as a last resort and you're flogging it off
Rusho
 Posted: Thu Apr 19, 2012 3:42 pm |
bakerboy wrote: dont put chemiweld in if you have a gasket, do it properly if your going to keep it, on use chemiweld as a last resort and you're flogging it off And if your keeping it get the had crack tested and checked for straightness. Also, replace the timing belt and water pump while your in there
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Thu Apr 19, 2012 4:53 pm |
Rusho wrote: cairns27 wrote: Cheap fix....Chemiweld and oil change
bye If its using that much water I doubt chemiweld would do anything My coily with a cracked G16a (actually 2 different cracks) in it would empty the overflow tank after an hours driving. After a chem-i-weld treatment as per the instructions it is fine even a year later, but it doesn't get driven much anymore. Originally, it always used a small amount of water but the crack became worse after a couple of radiator flushes. I suspect it had had a similar treatment before. I have also put chem-i-weld into my LWB Vitara. I discovered it had a cracked block when it did a headgasket but it definitely isn't using water now.
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Thu Apr 19, 2012 5:46 pm |
Reubs
 Posted: Thu Apr 19, 2012 10:21 pm |
Fatzook wrote: haurp00ned wrote: yeah the oil is a bit milky Dead head gasket or cracked block. Oh, in that case chem-i-weld won't fix that (according to the instructions anyway)...
Lockie666
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1874 Location: Perth
 Posted: Thu Apr 19, 2012 10:36 pm |
Chemiweld is the devil.
_________________ helloo
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Fri Apr 20, 2012 12:31 pm |
My wife had a sigma a few years ago That leaked green coolant out the tail pipe as fast as u could pour it in I cheme welded that up and it lasted 18 months Then I did it again and sold the car 6 months later
atari4x4
 Posted: Fri Apr 20, 2012 12:53 pm |
3 tubs of chemiweld in a TB42 GQ & it was like new again, well new enough to sell.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Fri Apr 20, 2012 12:54 pm |
got_bar_work wrote: My wife had a sigma a few years ago That leaked green coolant out the tail pipe as fast as u could pour it in I cheme welded that up and it lasted 18 months Then I did it again and sold the car 6 months later Not buying anything from you then..
_________________ mlm
haurp00ned
 Posted: Fri Apr 20, 2012 1:48 pm |
done oil change and flushed radiator out again put knew coolant in and chemiweld now just too wait and see what the turn out is. cheers for all help
