hi mates. got a problem with my car. happend after taking off from the lights last night. took off and herd big clunk clunk bang noises. couldnt drive without it making noises and grabbing/almost jamming up fully. had to tow home
i jacked it up now and it seems to make the noises even in neutral in 2 wheel drive when i let clutch out. dunno whats happened. was thinging diff broken or uni joint but its doin it in neutral and the wheels spin in neutral once clutch gets let out. back wheels are jacked up
vid here mates. some times im letting clutch out in gear. some are neutral.
after another look think it might be the front uni joint, the one closest to the transfer case on the gearbox to transfer case shaft. dunno why it wants to spin the wheels with gearbox in neutral though. seems it will do it sometimes but will stop and icanstop the wheels with hand
yer its the front driveshaft uni. pretty sure. its just turning in neutral sometimes coz its gay i guess. weight of the car on the ground would hold that probably under normal conditions
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
Posted: Sat Apr 21, 2012 4:23 pm
Get under the car, and wiggle the uni joint. If there is slop in it, its fucked. If not, then its something else. All that vieo shows is that there is a noise.
Joined: Mon Feb 14, 2011 8:19 am Posts: 1966 Location: Couridjah
Vehicle: 1985 Holden Drover
Posted: Sat Apr 21, 2012 5:04 pm
probly uni joints. well il fix them first. will do rear and jackshaft one
certainly sounds like uni joint noise based on one i had previously with hilux diffs.
theres not really anything thatd make that noise in transfer cast is there? thought if it was transfer case itd make similar noises to when ya miss a gear and stuff?
Posted: Sat Apr 21, 2012 5:58 pm
abclarke : that perfectly fine. Stop whinging
Absolutely is. Same with the gearbox. Damaged bearings, stripped gears sound exactly like that.
Take the jack shaft out and have a REAL good look at it. If that doesn't tell you anything, drop the oils from your transfer and gearbox. If its a problem in there, you'll most likely find sizable bearing or gear tooth fragments.
what bits do a rekn is broken? most likely my 6.5 gears or something else in there? looks like the top of a gear though but i dunno what anything else looks like in there. able to get single gears off the suppliers?
how do i split the transfer case? i have just removed it and all the bolts holding the halfs together and also the bolts where the bit is near the transfer lever?
i wanna open it up tomorrow so be good to know how to do it
Users browsing this forum: No registered users and 230 guests
