It is currently Tue Aug 04, 2026 12:27 pm
Post Posted: Sat Apr 21, 2012 12:27 pm
hi mates. got a problem with my car. happend after taking off from the lights last night. took off and herd big clunk clunk bang noises. couldnt drive without it making noises and grabbing/almost jamming up fully. had to tow home
i jacked it up now and it seems to make the noises even in neutral in 2 wheel drive when i let clutch out. dunno whats happened. was thinging diff broken or uni joint but its doin it in neutral and the wheels spin in neutral once clutch gets let out. back wheels are jacked up
vid here mates. some times im letting clutch out in gear. some are neutral.
http://youtu.be/5LqHT4TThKk
any ideas
Post Posted: Sat Apr 21, 2012 12:39 pm
after another look think it might be the front uni joint, the one closest to the transfer case on the gearbox to transfer case shaft. dunno why it wants to spin the wheels with gearbox in neutral though. seems it will do it sometimes but will stop and icanstop the wheels with hand
Post Posted: Sat Apr 21, 2012 1:00 pm
yer its the front driveshaft uni. pretty sure. its just turning in neutral sometimes coz its gay i guess. weight of the car on the ground would hold that probably under normal conditions
Post Posted: Sat Apr 21, 2012 1:06 pm
Your posts are confusing.
The jackshaft or the front driveshaft?
Gbox in neutral, turning the jackshaft will drive the car wheels..
Transfer in 2wd should only drive the rear shaft. Front shaft stays stationary with hubs unlocked also.
Post Posted: Sat Apr 21, 2012 1:17 pm
think its called jackshaft after looking on ebay for unijoints. from gearbox to transfer
jackshaft turns sometimes in 2 wheel drive with gearbox in neutral. dunno why. can stop it with hand on tyre.
think i found problem anyway
Post Posted: Sat Apr 21, 2012 1:31 pm
The jackshaft will turn with gbox in neutral with wheels in the air.
If you put the gbox in gear, it wont turn..Because then your turning the whole motor over also..
If that jackshaft is only turning sometimes, you have other problems.
Vehicle: 1985 Holden Drover
Post Posted: Sat Apr 21, 2012 1:51 pm
Pics would help ALOT i think.
1989 WT Sierra.
Post Posted: Sat Apr 21, 2012 2:07 pm
acid trips arnt good for ya brain :rofl:
 Profile YIM
Post Posted: Sat Apr 21, 2012 2:21 pm
pics of what? we have determined it is called the jackshaft now. called it the wrong thing first
better check more stuff then. maybe not the uni joint on jackshaft :(
Post Posted: Sat Apr 21, 2012 4:03 pm
vid
Post Posted: Sat Apr 21, 2012 4:23 pm
Get under the car, and wiggle the uni joint. If there is slop in it, its fucked. If not, then its something else. All that vieo shows is that there is a noise.
Post Posted: Sat Apr 21, 2012 5:01 pm
yer been under car and shook them. that one moves abit. maybe 1mm play. shud there be aboslutly no play in them?
and play in the very rear one of the car also.
Post Posted: Sat Apr 21, 2012 5:04 pm
Uni joints should have ZERO play. If there is any more than ZERO, replace the joint.
You mean like this?
1989 WT Sierra.
Post Posted: Sat Apr 21, 2012 5:10 pm
probly uni joints. well il fix them first. will do rear and jackshaft one
certainly sounds like uni joint noise based on one i had previously with hilux diffs.
theres not really anything thatd make that noise in transfer cast is there? thought if it was transfer case itd make similar noises to when ya miss a gear and stuff?
Post Posted: Sat Apr 21, 2012 5:58 pm
abclarke : that perfectly fine. Stop whinging :thefinger:
Absolutely is. Same with the gearbox. Damaged bearings, stripped gears sound exactly like that.
Take the jack shaft out and have a REAL good look at it. If that doesn't tell you anything, drop the oils from your transfer and gearbox. If its a problem in there, you'll most likely find sizable bearing or gear tooth fragments.
Post Posted: Sat Apr 21, 2012 7:42 pm
ok thanks guys
Post Posted: Sat Apr 21, 2012 10:47 pm
broken gear pieces in transfer case :(
Post Posted: Sun Apr 22, 2012 12:48 am
Bingo!
Sorry for your loss. :cry:
Post Posted: Sun Apr 22, 2012 1:00 am
what bits do a rekn is broken? most likely my 6.5 gears or something else in there? looks like the top of a gear though but i dunno what anything else looks like in there. able to get single gears off the suppliers?
how do i split the transfer case? i have just removed it and all the bolts holding the halfs together and also the bolts where the bit is near the transfer lever?
i wanna open it up tomorrow so be good to know how to do it
Post Posted: Sun Apr 22, 2012 1:07 am
Go to the lowrange or calimin sites and download the gear installation instructions. They will walk through tear down proceedures.
Sounds like your 6.5's have given up on you.
Post Posted: Sun Apr 22, 2012 1:22 am
just returned from lowrange site. yeah appears the gears have broken. will see what e find tomorrow :(
Post Posted: Sun Apr 22, 2012 8:41 am
The 6.5s have a no questions asked return dont they?
1989 WT Sierra.
Post Posted: Mon Apr 23, 2012 1:36 pm
dunno. will confirm they are infact their gears when i get em out then look into something maybe. i didnt buy them but
wonder why they would have broken?
Users browsing this forum: No registered users and 280 guests
