It is currently Tue Aug 04, 2026 7:22 pm
Vehicle: 2000 Grand Vitara Sports
Post Posted: Sun May 06, 2012 4:17 pm
Hi, I have noticed a whine when accelerating in my 2000 GV Sports edition. Seems to be from engine bay area and only occurs under acceleration. If I back off the gas the whine stops. Any ideas as to cause? I think it has occurred since I changed the oil and replaced filter using Castrol Magnatec 10/40 and a Suzuki filter. Used Nulon oil cleaner in the process.
Vehicle: 1999 Jimny
Post Posted: Sun May 06, 2012 7:14 pm
Be interested to see what you come up with for this....
Post Posted: Sun May 06, 2012 9:02 pm
What area you from? If you can post up a vid of the noise it makes it may help.
Vehicle: 02 GV
Post Posted: Mon May 07, 2012 9:37 am
mine does the same under heavy acceleration at high revs. doesn't make any other noises, it does come from the engine bay and is an auto. it's mechanically A1 with very good compression and vacuum.
it almost sounds like engine noise you get through the stereo but from the engine bay.
its always serviced every 5000km's.
Users browsing this forum: Beery and 303 guests
