It is currently Mon Nov 02, 2026 8:12 am
Post Posted: Sat Apr 28, 2012 6:25 pm
Ok so I just got myself a new Sierra but having problems with
the starter. The car has a 1.6 vitara efi with Sierra gearbox, bens adapter.
When you try to start the car it makes the worst meshing noise.
So had the starter rebuilt and still the same, so did a search and
found out the starter is out of a grand vitara 2.0L. I tried a Sierra 1.3L starter and did the same noise.
Any help would be great.
Post Posted: Sat Apr 28, 2012 7:32 pm
Try using a 1.6 vit starter ;-)
Post Posted: Sat Apr 28, 2012 7:34 pm
If 2 starters do the same thing I'd pull the inspection plate from the lower bellhousing and check the ring gear teeth on the flywheel.
A 1.3 starter needs grinding to fit properly with a 1.6/Sierra box.
Post Posted: Sat Apr 28, 2012 8:16 pm
I had I look at the ring gear and it has little wear
but it doesn't look to bad, I am going to order a new 1.6 vitara
starter and see how that goes. If that doesnt work I will have to find a new
Flywheel or ring gear, not looking forward to pulling the gearbox out. Is a 1.6 vitara starter different
to a 2.0L starter.
Post Posted: Fri May 04, 2012 7:07 pm
Ok so I got a new vitara starter and it's still not starting
When you turn the key the central locking clicks and the stater
sounds like its still meshing. Could it be a power thing.
Vehicle: Sj70 tintop
Post Posted: Fri May 04, 2012 7:09 pm
bad earth or you need the clicky starter fix?
can you roll start it?
Sj70 tintop
Post Posted: Fri May 04, 2012 7:19 pm
Yer it roll starts but I can't always park on a hill
Vehicle: 75 Cruiser
Post Posted: Fri May 04, 2012 8:10 pm
I had the same issue with a 1.6, sounded like some kind of turbo starter, could never work out why it sounded like that but was never a problem. I know of someone else that had the same issue, but they didn't worry about it either.
Post Posted: Fri May 04, 2012 8:38 pm
The sound is really bad like the starter is meshing big time
with the flywheel, the flywheel has small amount of wear but it's not
to bad. What else could it be
Users browsing this forum: No registered users and 60 guests
